4wd causing grinding noise from axle u-joint - JeepForum.com
post #1 of 2 Old 07-06-2010, 06:16 PM Thread Starter
Wrangler19
Today I was at the river, and the drive down there is pretty washed out. So on my way out, i got caught in kind of a rut, so I put it in reverse, and I just spun the wheels. So i switched into 4 HI, and it got me out, thankfully. But I heard a loud grinding noise from my front drivers side axle, and something maybe from the front drive shaft, that i felt in the steering wheel, I know that my u joint is going bad on the front drivers side, but could it have caused that much noise and grinding?
1998 4cyl TJ, 4in RC series 2 lift, 33x12.50 BFG KM1's.
[QUOTE =inglisleslie;11598716]we only care about 4BT...jeep is run by slow people now who like plastic everything [/QUOTE]
Wrangler19 is offline
post #2 of 2 Old 07-06-2010, 08:20 PM
BlueFlame
BlueFlame's Avatar
yep. 10 chars
BlueFlame is offline
grinding , noise , axle u-joint , u joint , 4wd , 4hi , TJ
E brake causing rattle noise. Jeepmed TJ Wrangler Technical Forum 3 07-14-2010 07:18 AM
grinding noise, could this be a bad u-joint? nathanielt TJ Wrangler Technical Forum 8 09-23-2009 10:16 PM
Ball, joint, U-joint, control arms? Clunking noise. FritzTJ TJ Wrangler Technical Forum 11 09-18-2009 10:59 AM
What could be causing this noise? black05tj TJ Wrangler Technical Forum 1 07-10-2007 02:14 PM
Grinding/rubbing noise from front axle jeepthis TJ Wrangler Technical Forum 4 10-10-2005 06:41 AM
