4th gear problems - JeepForum.com
post #1 of 1 Old 05-17-2008, 09:06 PM Thread Starter
03Wrangler
03Wrangler's Avatar
2010
4th gear problems
i have the 5 speed transmission behind the 4.0 in my 03 wrangler X...
when i go up/down hills in 4th gear and get to 2000 rpms (60 mph) and push the clutch in to shift out of fourth, it sticks... i dont ever force it, if i cant move it easily, i dont force it out...
if i rpm match back to 2000 rpms, it will pop out... and if i double clutch that seems to do it also...
it only does it 20% of the time...
what is my problem, bad synchro?
thanks, erick
03Wrangler is offline
D44 Gear Problems, shaft problems. lazerusrm TJ Wrangler Technical Forum 7 04-09-2008 05:29 PM
2 nd gear problems. RedRock84 JK Wrangler Technical Forum 3 02-10-2008 08:58 AM
4th gear problems FranV TJ Wrangler Technical Forum 2 09-08-2007 10:41 AM
2nd gear problems OB1 YJ Wrangler Technical Forum 3 04-11-2005 06:29 AM
4wd low gear problems nyconickk TJ Wrangler Technical Forum 10 12-20-2004 08:44 AM
