4th gear problems - JeepForum.com
post #1 of 3 Old 09-08-2007, 12:00 AM Thread Starter
FranV
4th gear problems
My 97 Tj with 33 X12.5's 6cyl seems to have lost all power in 4th gear. 5th gear was never really any good, but it seems like recently I just lost all power in 4th gear. the jeep was sputtering and hesitatin when accelerating under load. I replaced the plugs, wires, tps sensor and downstream o2 sensor, I can't get my jeep to go over 55 mph in 4th on a flat road...help!!!
FranV is offline
post #2 of 3 Old 09-08-2007, 12:21 AM
minesweaper
update your profile so we know what you have. have you geared it? 33's you should go for at least 4:10 gears if not 4:27 or 4:56. how long have you had the 33"s on there? we need more info? how does it run up to 40-45?
'03 Wrangler X / 5 SPD
15X10 ION Wheels 33X12.50 BFG Mud Kings
2" FabTech BB Lift, JKS Discos, Cobra 19 CB, 48" High Lift, Bed Liner, MML,BL
SYE, CV Drive Shaft, Radiator, Oil Pan, and Steering Box Skids
8.8 w/4.10s and LSD
minesweaper is offline
post #3 of 3 Old 09-08-2007, 11:41 AM Thread Starter
FranV
I bought the jeep used it already had a 3 inch lift and 33 x 12.5's. about 80k miles. I am pretty sure the gearing is about 3:53. I would love to go to 4:10 but can afford the $1500 right now. I went mudding and all my problems started after that. Sputtering, stalling etc. I put new plugs in and new wires, but things just seem to have gotten worse.
FranV is offline
4th gear problems 03Wrangler TJ Wrangler Technical Forum 0 05-17-2008 10:06 PM
D44 Gear Problems, shaft problems. lazerusrm TJ Wrangler Technical Forum 7 04-09-2008 06:29 PM
2 nd gear problems. RedRock84 JK Wrangler Technical Forum 3 02-10-2008 09:58 AM
2nd gear problems OB1 YJ Wrangler Technical Forum 3 04-11-2005 07:29 AM
4wd low gear problems nyconickk TJ Wrangler Technical Forum 10 12-20-2004 09:44 AM
