4cylinder swap to 6 cylinder Is it worth the trouble??? - JeepForum.com
post #1 of 3 Old 04-09-2013, 10:22 AM Thread Starter
gtnutz
2010 JK Wrangler
Ok so my parents have a 1997 Wrangler 4-cylinder 5-speed base model that Iíve been given / purchased for a very small price (its been in the family for 12 years). I also have a donor fully running 1998 Jeep Cherokee with the 6-cylinder motor.
What type of headache would I be in for if I decided to pull the anemic 4cyl out and replace it with the 6cyl with 15k on a new rebuild motor???
Iím not looking to have the Jeep inactive or unusable for long I was hoping that itís a direct bolt in type swap.
Or is it even worth the trouble, as I will be selling off my other cars and only driving this one for the next year or so.
gtnutz is offline
post #2 of 3 Old 04-09-2013, 11:49 AM
Jeepsr4me
Other than the motor mounts is a direct fit. You got to cut and weld those back in right spot.
You have 4.10 gears with a 5 speed. So consider that when installing the 6. You will not be able to use the 5speed from the 4 banger. I would install the cherokee trans either if its auto or 5 speed. Wiring can be as simple as splicing in 2 more injectors or ordering a OEM wiring harness from junked TJ that had 6 stock..
Worth it money and time wise, no. Worth it for a learning experience yes. Worth it to get the cherokee auto, yes. Time wise you will have to be on a schedule to do it all in a weekend. Drive shafts will need to be cut and adjusted for the new length.
READ there are a million post on this. Been done to point nothing you will run across has not been worked out and overcome.
Jeepsr4me is online now
post #3 of 3 Old 04-09-2013, 12:15 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
For the amount of time and labor that goes into a engine swap, a v8 is pretty similar in cost and time.
That said, you're kinda stuck with an automatic with a v8 unless you like a real challenge.
My builds:
and
or follow us on
spyder6 is offline
