4cyl vs. 6cyl - Page 2 - JeepForum.com
post #16 of 61 Old 03-11-2011, 02:29 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
There is no benefit to getting a 4 cylinder other than the fact that they usually cost about $3000 less than the 6.Gas mileage is the same also.
TheBoogieman is offline
post #17 of 61 Old 03-13-2011, 04:33 PM Thread Starter
RedStep
Sorry stopped getting email notifs from this thread for some reason >.> lol but thanks for all of your help guys, do TJ's often come with rear D44's on them or should I be spending a lot of time looking?
RedStep is offline
post #18 of 61 Old 03-13-2011, 04:39 PM
hustler905
There were a lot of TJs made, I would spend the time looking for one with a D44. I wish I did.
hustler905 is offline
post #19 of 61 Old 03-13-2011, 04:50 PM Thread Starter
RedStep
Yea I hear ya on that. I looked into just buying a D44 too and it was like 1500 bucks min too which also sucks pretty bad
RedStep is offline
post #20 of 61 Old 03-13-2011, 06:38 PM
slamtheright
i have had both, the six has way more power, but the four you dont have to worry about breaking driveline componets.............
slamtheright is offline
post #21 of 61 Old 03-13-2011, 07:31 PM
BlueFlame
BlueFlame's Avatar
About half of them did.
In my opinion its worth finding one up front,
(unless of course you're going to build a big jeep with even bigger axles anyway...)
BlueFlame is offline
post #22 of 61 Old 03-13-2011, 07:40 PM Thread Starter
RedStep
I think the 44 is the biggest I'd go for now, so I'll probably wind up looking until I find one with either front or rear 44. It's funny that you say up front though because a lot of people only talk about the rear
RedStep is offline
post #23 of 61 Old 03-13-2011, 07:57 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
What componets would that be?...
Knuckelhead is offline
post #24 of 61 Old 03-13-2011, 08:37 PM
Diana6971
How do you know?
How do you tell which you have? I have an 06' Rubicon, I know it has a 4.10 rear. Not sure if it has a Dana 44 front or back?
Diana6971 is offline
post #25 of 61 Old 03-13-2011, 08:39 PM
BlueFlame
BlueFlame's Avatar
by "up front" I meant "when you buy"
The only front D44 in a TJ will be in the Rubicon. ANd that's not REALLY a 44, it's a 44 center (with some parts that don't work with Normal D44 parts) and D30 outer parts, so it is not one bit stronger than a D30.
post #26 of 61 Old 03-13-2011, 08:42 PM Thread Starter
RedStep
The difference between the 35 and 44 is pretty well laid out here: (look for the pictures)
http://www.jeepforum.com/forum/f9/4x...nswers-628225/
And that makes more sense now haha, so what you're saying is that if I find one with a 35 or 30 it won't make much difference than if I found one with a 44 center stock?
RedStep is offline
post #27 of 61 Old 03-13-2011, 09:31 PM
BlueFlame
BlueFlame's Avatar
No.
Rear is either a 35 or 44. 44 is much stronger.
Front is either a 30 or rubi44. They have approx the same strength.
post #28 of 61 Old 03-13-2011, 10:21 PM Thread Starter
RedStep
ok thanks for clarifying
RedStep is offline
post #29 of 61 Old 03-13-2011, 11:30 PM
Southside1212
Either way you will want a V8 eventually...
Southside1212 is offline
post #30 of 61 Old 03-13-2011, 11:41 PM
btn
Aside from similar gas mileage, the 6 is naturally perfectly balanced. I4s have inherent roughness. Also, the 6 is known to be very durable and last forever.
btn is offline
door , tj
4cyl vs 6cyl boaman8USC YJ Wrangler Technical Forum 19 02-03-2007 12:57 AM
4cyl vs 6cyl sandruvious YJ Wrangler Technical Forum 10 12-03-2006 10:59 AM
4cyl. to a 6cyl. Saturntech45 TJ Wrangler Technical Forum 4 11-12-2006 02:16 PM
4cyl OR 6cyl pajeepgrl YJ Wrangler Technical Forum 13 07-31-2005 09:03 PM
90 YJ 4cyl?? 6cyl?? and how $$$ AK1904 YJ Wrangler Technical Forum 1 05-05-2003 08:20 PM
