4cyl - 6cyl swap - HELP!! - JeepForum.com
post #1 of 6 Old 02-02-2012, 04:23 PM Thread Starter
CowDust03
I am looking to purchase a 2003-2006 TJ as a daily driver\beach\ranch vehicle. Most all mods will be minor with safety and economy in mind. That being said, I have not purchased the vehicle yet. I was wondering (and with everyone's expertise to help) if the motor mounts and transmission mounts were the same for 4-cyl as the 6-cyl. Since most every mod will be tame, stock engine and transmissions will suffice. Knowing if upgrading will be less technical than custom mounts will help me decide what my purchase has to be. Any help will be appreciated!
CowDust03 is offline
post #2 of 6 Old 02-02-2012, 05:28 PM
herbiehind
many have done the upgrade . you'll need the wiring harness too . plus motor mounts moved . t-case skid is same location i believe .
herbiehind is offline
post #3 of 6 Old 02-02-2012, 05:34 PM
greene69
Why not just buy a 6 cyclinder to start with? Would be cheaper and you could just drive it. I would recommend an auto for the beach sand, i have been driving on sand since 1994 and an auto is the way to go.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline
post #4 of 6 Old 02-02-2012, 05:41 PM
texas_yj
it is definately not worth this swap, its the same amount of work to do a V8 swap. The you will need the engine, tranny, Transfer case, wiring harness, and computer to make it all work. then you have to make/fabricate/cut off doner jeep - the motor mounts and weld in, you might as well just buy a 6 cyl. to begin with. and for future reference, no the transmission will not bolt up, the xfer case has different spline count, and motor mounts are differnt.
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline
post #5 of 6 Old 02-02-2012, 05:44 PM
scot68
Originally Posted by greene69 View Post
Why not just buy a 6 cylinder to start with? Would be cheaper and you could just drive it. I would recommend an auto for the beach sand, i have been driving on sand since 1994 and an auto is the way to go.
X2.. However if you can't pass on this particular Jeep and your already thinking about a motor swap why not do a Magnum 5.2L or 5.9L?? Basically not much more work. The Jeep 4.0L is a great little engine but if I were swapping that's what I would do..
scot68 is offline
post #6 of 6 Old 02-02-2012, 05:53 PM Thread Starter
CowDust03
That's the information I was looking for. I was hoping to be able to get a 4cyl cheap and run it until it quits, stock piling other upgrades, and do the whole swap over at once. I'm now just going with the 6cyl and will piece it together as I go. Thanks everyone!
engine swap , motor mounts , tj
what parts do I need to swap out a 4cyl to a 4.0 6cyl? wrangler-94 YJ Wrangler Technical Forum 6 01-01-2011 11:39 AM
4cyl to 6cyl swap csheet30 YJ Wrangler Technical Forum 1 03-23-2010 06:15 PM
engine swap 95 4cyl to 90 6cyl Darkskye18 YJ Wrangler Technical Forum 5 02-18-2008 08:17 AM
4cyl for 6cyl swap, how complicated? eprovenzano TJ Wrangler Technical Forum 16 01-11-2008 05:18 PM
anyone swap a 4.0L 6cyl in place of a 2.5L 4cyl? TXST8tj TJ Wrangler Technical Forum 4 01-11-2008 03:31 PM
