42rle temp gauge - JeepForum.com
post #1 of 75 Old 06-30-2009, 07:25 AM Thread Starter
04TJSport
42rle temp gauge
any one know where i can get a temp gauge for my tranny? also and how easy is it to install?
" All Out of Road" Vilseck Jeep Club
04 TJ 3 in. BL 2in. CS 4.88 power inverter CAI snorkel
Silver Jeep Club Number 23
04TJSport is offline
post #2 of 75 Old 06-30-2009, 07:42 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
its an aw4 but you get the idea.
http://www.stu-offroad.com/engine/aw-4/aw-4-4.htm
there is a temp gauge already in the trans, and you could conceivably access the info through X-Gauge using a Scangauge II, but I have no idea how to do this.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 75 Old 06-30-2009, 07:52 AM
roadkill
scanguage doesn't have an app or code for trans temps on the TJ/LJ. I wish it did.
roadkill is offline
post #4 of 75 Old 06-30-2009, 08:00 AM
Unlimited04
I was hoping someone smart could use X-Gauge to program their own code, thats what the feature is for.
Info for someone smart:
http://www.scangauge.com/support/pdfs/XGAUGE.pdf
http://www.scangauge.com/support/pdf...e%20Coding.pdf
Useful Write-Ups:
Funny:
post #5 of 75 Old 06-30-2009, 09:01 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Since Jeep trannies don't come with a tranny temp sender, no gauge is going to be able to give the tranny's temp. You need to either weld a tranny temp bung into the pan or place a sender in the coolant line before you can know the temperature.
I have senders in both the pan and line, and have a switch for my tranny temp gauge (B&M and Autometer make them) so I can check both temps.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #6 of 75 Old 06-30-2009, 09:37 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Since the 42RLE is electronic and uses a TCM, there is probably some sort of temp sender already present.
Unlimited04 mentioned this, but I'm not familiar enough with the 42RLE to say one way or another.
Wheelin98TJ is offline
post #7 of 75 Old 06-30-2009, 09:43 AM
Unlimited04
the 42RLE does have a temp sensor in the side of the housing. the TCM uses it to determine shifts & lockup depending how warm the trans is.
DTC codes for it:
42RLE Code (DTC) P0711 Trans Temp Sensor, No Temp Rise After Start
42RLE Code (DTC) P0712 Trans Temp Sensor Voltage Too Low
42RLE Code (DTC) P0713 Trans Temp Sensor Voltage Too High
42RLE Code (DTC) P0714 Transmission Temperature Sensor Intermittent
Its wire #54 on the pinout, page 8:
http://atsg.biz/articles/html/Jeep%2...Supplement.htm
the 2004 FSM outlines the shift scheduling in Section 3.2.2 based on trans oil temperature - http://www.jeepforum.com/forum/showp...0&postcount=43
Useful Write-Ups:
Funny:
post #8 of 75 Old 06-30-2009, 09:57 AM
Jerry Bransford
Administrator
It may have a sensor to tell the computer if it's too hot or too cold but I don't believe it can give the kind of output needed for a gauge to know the actual transmission temperature which requires an actual temperature gauge sender.
Getting
post #9 of 75 Old 06-30-2009, 10:32 AM
NotURMailman
Actually I believe it is an actual sending unit that sends a variable voltage signal to the PCM based on the temperature. If you could pinpoint the exact relationship of voltage level to temperature, you should be able to use it to run a digital gauge.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #10 of 75 Old 06-30-2009, 11:17 AM
Jerry Bransford
Administrator
What do you base that on?
Getting
post #11 of 75 Old 06-30-2009, 11:53 AM
Wheelin98TJ
JEEP FREAK
Here is a graph from the FSM:
post #12 of 75 Old 06-30-2009, 12:31 PM
Unlimited04
oh man, thats awesome info! now we just need to put together the TXD, RXF, RXD and MTH codes to program into the X-Gauge to read voltage.
I tried 3 of the Ford Trans temp sensor codes and got a constant value of 5126 back...definitely not it.
EDIT: I just called Linear-Logic (they make the Scanguage II) - I sent them an email w/ the above chart and talked with a knowledgable person. They should get back to me soon about the TXD, RXF, RXD and MTH codes (if/how they can read this sensor).
Useful Write-Ups:
Funny:
post #13 of 75 Old 06-30-2009, 08:29 PM
mudb8
want it rite or rite now?
mudb8's Avatar
I've dabbled with the 42rle sender also and just ended up tapping the the line...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #14 of 75 Old 07-01-2009, 05:07 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Install the sending unit in the transmission line with a "T" fitting and a ground wire...
Knuckelhead is offline
post #15 of 75 Old 07-01-2009, 05:43 PM
Strizzy
So does tapping into the line with a digital temp gauge give correct readings?
Strizzy is offline
94 yj temp gauge..... need help!!!! jpringles YJ Wrangler Technical Forum 27 10-23-2009 04:45 PM
Is this temp normal? Temp Gauge Pic !!! Thunderstrike TJ Wrangler Technical Forum 23 06-26-2007 09:01 PM
Temp. gauge shark3471 YJ Wrangler Technical Forum 5 05-10-2007 04:58 PM
90 vs. 93 temp gauge semper fi YJ Wrangler Technical Forum 0 03-18-2007 09:37 AM
Temp Gauge Levin2000 YJ Wrangler Technical Forum 3 03-25-2005 07:10 AM
