42RLE Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 42RLE Questions
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 06-20-2014, 04:52 PM   #1
BlaketheSnake
BlaketheSnake's Avatar
42RLE Questions
Transmission has been just fine until this morning.
Backed out of the garage just fine...shifted into drive and it had a long hesitation and shifted a little odd thru the gears. After I made it to the end of my street it shifted fine all the way to work. Checked the fluid level an it was fine. It does seem to smell a little burnt. It's got only 125,000 miles on it and she's mostly stock other that a set if 265/75-16 BFGs. Is this normal wear for these trannys. I did have the fluid changed at 65,000 miles.
Also does anyone have a remanufactured unit with a decent warranty?
Thanks,
Blake
Tread lightly or we all will be tree hugging hikers!
BlaketheSnake is offline   Reply With Quote
Unread 06-20-2014, 04:56 PM   #2
ravenworks
Be happy you got 125k on yours, mine bit it at 62k plus.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is online now   Reply With Quote
Unread 06-20-2014, 05:42 PM   #3
hokahay
The maintenance schedule calls for changing the fluid and filter every 30,000.
Google-fu turned up a couple. There must be more.
http://www.smartpartsauto.com/automa...2rle_jeep.html
http://www.drivetrain.com/parts_cata...smissions.html
http://www.jeepsareus.com/p/JWTJ/152.html
Mine is a 2003 that just went over 100,000. knock on wood.
hokahay is offline   Reply With Quote
Unread 06-20-2014, 06:53 PM   #4
richardprovince
Not really sure what your asking? Is it normal for it to act up once, probably nothing is perfect. 130k on my 42rle and its perfectly good.
richardprovince is offline   Reply With Quote
Unread 06-20-2014, 07:01 PM   #5
gregstudeny
Mine did something similar last year. I replaced the fluid and filter. That didn't fix it. I took it to the dealership and they said there was an update for my transmission. They installed the update and its been fine since.
gregstudeny is offline   Reply With Quote
Unread 06-20-2014, 09:11 PM   #6
mike_dippert
hodophobic
mike_dippert's Avatar
There's a software update for 03-04 models. Don't remember what it addressed though. I'd change your fluid and filter, 60k is a long time, and the 42rle is notoriously hot.
You can't argue with ignorance.
Originally Posted by HurricaneRZA View Post
JF taught me that the 2.5L, Ax-5 and D35 together are so powerful that angels weep when I shift into 4LO.
The only thing a bicycle inner tube is good for, is tying a knot in the end of when you run out of condoms.
mike_dippert is offline   Reply With Quote
Unread 06-20-2014, 09:21 PM   #7
hokahay
I have a '03. Do you just go to the dealer? Is there a charge?
Will they complain bigger tires and different gears?
Unread 06-20-2014, 10:02 PM   #8
gregstudeny
Gears and tires didn't matter for me. I think I payed a small fee.
Unread 06-20-2014, 10:19 PM   #9
WhiteMtnJeep
The Punk Made My Day.....
WhiteMtnJeep's Avatar
They update the software in the PCM, I heard it was a couple hundred to do. 60K is too long between service. I would do a complete flush and filter (12qts of fluid). If it continues to act up you may need professional help. Mine only lasted about 70K before rebuild. The 42RLE's worst enemy is heat and they tend to run hot. Two of the best things you can do for long life in the 4-spd is regular fluid/filter changes and add an external cooler. Especially if you run oversize tires.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Polyphase Meterman IBEW Local 387
Work with enthusiasm as though you were working for the Lord rather than for man.
http://www.treadlightly.org/
Siena Jeep Owner's Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
WhiteMtnJeep is offline   Reply With Quote
Unread 06-21-2014, 05:12 AM   #10
BlaketheSnake
Thanks guys!!!
I'm heading out to get it serviced today I hope, if they can shuffle me in.
I hope it ain't gonna need an overhual I can't handle a long down time she's my only transportation and .... I just bought a garage with a house attached to it.
Thanks again!!!
Unread 06-21-2014, 10:20 AM   #11
hokahay
I stopped by my local dealer and asked about the firmware upgrade for the 42RLE of my 2003. There is one. He said it fixes rough shifting from 4th to 3rd. Cost was $85.00. I'll probably have it done Friday afternoon. I always learn things here on JF! Thanks to all.
