42RLE Problems - JeepForum.com
post #1 of 44 Old 01-14-2008, 07:06 PM Thread Starter
SportTJ4x4
42RLE Problems
Im having a major problem with my 42RLE its not shifting correctly and its causing my engine to ping alot. Ill be cruising at 55mph and then get to a hill once i start going up i slow down the transmission doesn't down shift or unlock the converter and then the pinging (rattling sound). Is there a chip or something i can buy to make this transmission down shift earlier, or anything I can do about this.
Thank you very much in advance,
Mike
SportTJ4x4 is offline
post #2 of 44 Old 01-14-2008, 07:34 PM
jeep rio
They make shift kits for it, Im not sure of the manufacturer but I know they do! Also have you regeared it yet? and what size tires are you running
1997 XJ Sport 2 Door- High country suspension and skid plate package.
2006 TJ- Custom lift 4in Full traction springs, OME shocks, Kilby skid plates and bumper, Full traction 3 link in rear, JKS control arms upper lower, Banks exhaust, Edge trail jammer, 4.56's and true trac front, Eaton elocker rear. D30, D44
1995 YJ Rio Grande- 4.0l Swap 3.5 in 4wd hardware lift, Ford 8.8 Rear 4.10 gears.
jeep rio is offline
post #3 of 44 Old 01-14-2008, 07:47 PM
nicolas-eric
the 42rle in my 06 tj had some problems. it didn´t like to switch the O/D off.
after a software update at the local jeep dealer evereything worked fine.
4" OME & 1" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
nicolas-eric is offline
post #4 of 44 Old 01-14-2008, 09:01 PM Thread Starter
SportTJ4x4
im running stock 30s
post #5 of 44 Old 01-14-2008, 09:06 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
take it back to the dealership. i had similar problems and they reflashed the TCM, it helped alot. the tranny still sucks however, it still shifts into OD at 45mph, and i still lose speed and it spends all day kicking between 3rd/4th if i drive at 45mph, 40mph no problem, 60mph no problems, but anything in between, you just need to use the OD OFF button for when you know you want 3rd.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 44 Old 01-14-2008, 09:09 PM Thread Starter
SportTJ4x4
ok great thank you how much does taking it the dealer run you
post #7 of 44 Old 01-14-2008, 09:14 PM
Unlimited04
i took it in three times, was free every time (did it under warranty). first problems started brand new, got fed up by 3k miles and again at 9k miles, and again at 20k miles. is it still under warranty? there is a TSB on the TCM module, so you should be able to make a case about it needing to be reflashed.
Useful Write-Ups:
Funny:
post #8 of 44 Old 01-14-2008, 09:29 PM Thread Starter
SportTJ4x4
my warranty has a 100 dollar deductible so was it totally free or did you have to pay the 100 bucks
thank your for all the help so far
post #9 of 44 Old 01-14-2008, 09:40 PM
Unlimited04
i did it all before the 3/36k was up, so it was totally free.
they will probably charge you a diagnostic fee, and rape you with labor...but hey, they are the only ones that have the new TCM prog....
Useful Write-Ups:
Funny:
post #10 of 44 Old 01-15-2008, 08:41 AM Thread Starter
SportTJ4x4
So the only way is to bring it to the dealer? Nobody makes a chip or anything for it?
post #11 of 44 Old 01-15-2008, 10:16 AM Thread Starter
SportTJ4x4
post #12 of 44 Old 01-15-2008, 11:19 AM
chefdab
The shift kit you referred to is made by Transgo.
David
2005 LJ w/ RE 5.5 LA riding on 35"MT/Rs
"Roads, where we're going we don't need roads."
... at what point has "NEED" ever come into play when it comes to Jeep upgrades
Originally Posted by ranmannm View Post
I'm a idiot so be genital.
chefdab is offline
post #13 of 44 Old 01-15-2008, 11:34 AM
Unlimited04
Read my previous post:
The Transgo shift kit will help, but the tranny is still going to suck until you get the right program in the TCM. It will still cost you a hundred plus in labor to get that shift kit installed, unless you want to do it yourself.
Useful Write-Ups:
Funny:
post #14 of 44 Old 01-15-2008, 08:33 PM Thread Starter
SportTJ4x4
I brought the truck to my transmission guy to see what he thought, he said jeep made it that way to save gas. Im not so worried about the lack of power that i am about the engine ping. Is the engine ping coming from the engine being under so much load?
post #15 of 44 Old 01-16-2008, 02:42 PM
garybattles
I have the same tranny. Mine shifts to OD at 48 mph, but no pinging, and I run on 32's. Something else is causing the pinging. I also hit the OD off switch unless I am on the freeway.
gmb08
garybattles is offline
42rle.... Blown! ChicagoRod TJ Wrangler Technical Forum 35 12-03-2009 05:58 PM
What is everyone using in the 42rle? ryan2022 TJ Wrangler Technical Forum 3 10-30-2009 08:56 AM
42rle -- > AW4? LOCKED UP TJ Wrangler Technical Forum 14 07-02-2009 07:45 AM
06 Rubicon 42RLE Drivetrain Problems Cheney TJ Wrangler Technical Forum 1 04-10-2009 07:15 PM
New A/t 42rle Fernandc TJ Wrangler Technical Forum 0 07-09-2003 08:18 PM
