42rle problems - JeepForum.com
post #1 of 8 Old 03-02-2011, 08:15 PM Thread Starter
APEDZ04LJ
42rle problems
Ok so i have an 04 lj, and i was having the usually heat tranny slip problem, and i dont get it anymore so thats not the problem but it would start to slip for a second and kind of buck then go when it was cold, i replaced the fluid and filter and filled it up to what everyone told me they manual said how much, it worked fine for a weak and started slipping again, so i added some tranny stabilxer i found at autozone and it worked fine for 6 months not a single buck nor slip well its back and im not quite sure what to do to get rid of my problem. Any suggestions?
APEDZ04LJ is offline
post #2 of 8 Old 03-02-2011, 08:26 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
drop the pan. if you see gold speckles in the fluid and have lots of metal shaving stuck to the magnet you need to rebuild the tranny. Note the 42RLE's don't seem to last long. Mine was dead at 50k, yet shifted fine as I drove it into the stealership, with two disintegrated snap rings and half a clutch pack destroyed.
how many miles are on it? did you use Mopar ATF+4?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 8 Old 03-02-2011, 08:28 PM Thread Starter
APEDZ04LJ
i just hit 88000 today, and yes it wast atf+4, when i pulled it last the magnet was completly covered, and whatd it cost ya to get rebuilt?
post #4 of 8 Old 03-02-2011, 08:29 PM Thread Starter
APEDZ04LJ
accidentaly double post
post #5 of 8 Old 03-02-2011, 09:22 PM
Unlimited04
mine was done under 7/70 warranty. a new/rebuilt tranny is $2000, so expect to pay a bit less than that for a full rebuild.
make sure to have a trans cooler installed in front of the radiator, and to have the TransGo shift kit installed.
Useful Write-Ups:
Funny:
post #6 of 8 Old 03-02-2011, 09:31 PM Thread Starter
APEDZ04LJ
ok so if im assuming id have to shell out 2000 on a tranny new or rebuilt if i swaped it out with a manual what would that be and would i need anything else other then the computer?
post #7 of 8 Old 03-02-2011, 09:36 PM
Unlimited04
theres a thread going on right now where a guy is swapping a NSG370 into a 2004 LJ...search it.
basically going to a manual is even more expensive, and a crapload of work. i looked into it pretty extensive...just decided to keep the 42RLE...and have somebody rebuild it stronger & better the 2nd time around.
Useful Write-Ups:
Funny:
post #8 of 8 Old 03-02-2011, 10:31 PM
RogueSpear2023
Swapping anything will be a pain, IMO the only decent swap is AW4, but even that will be expensive and a lot of work. Mine slips too when it is really cold out it has to do with it's warm up cycle, it slips more so the transmission will warm up faster. If it is doing it when it is warm you have a problem.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
Help. 42rle Transmission Problems P1776 lilcobrar TJ Wrangler Technical Forum 20 07-01-2015 07:24 AM
pleeeeease help!!!!! Shifting problems with 42RLE transmission emarlowe39 TJ Wrangler Technical Forum 0 10-20-2010 07:00 PM
What is everyone using in the 42rle? ryan2022 TJ Wrangler Technical Forum 3 10-30-2009 08:56 AM
06 Rubicon 42RLE Drivetrain Problems Cheney TJ Wrangler Technical Forum 1 04-10-2009 07:15 PM
42RLE Problems SportTJ4x4 TJ Wrangler Technical Forum 43 10-24-2008 05:18 PM
