42RLE Noise - JeepForum.com
post #1 of 8 Old 02-15-2012, 09:12 AM Thread Starter
grpatter
42RLE Noise
JF, I need your help on this one.
I know the manual is quite well known for it's 'marbles in a can' noise while the clutch is disengaged, but has anyone ever heard similar things in the auto?
It's an 05 LJ, and gives a strange whirring/'marbling' noise when near shift points. If I give it a bit more pedal it'll shift and stop, or if I let off a bit it'll stop. This usually happens between 3 and 4, but has happened between 2 and 3 as well.
Any thoughts?
grpatter is offline
post #2 of 8 Old 02-15-2012, 09:30 AM
Jeeprogue
sounds like your low on fluid, did you check it?
Jeeprogue is offline
post #3 of 8 Old 02-15-2012, 10:11 AM
4banged
Definitely not normal. The torque converter locks up in 3rd and 4th so maybe there's something wrong there but you'd have to take it to the dealer or tranny shop to diagnose that. I think we have the same tranny (42rle) and mine doesn't make any weird noises.
4banged is offline
post #4 of 8 Old 02-16-2012, 07:51 AM Thread Starter
grpatter
Yeah, fluid was the first thing I checked, still looking good there
4banged: Good (or bad..) to at least know this isn't normal, I'll keep looking and run by the shop to see what's up.
Thanks
grpatter is offline
post #5 of 8 Old 02-16-2012, 08:51 AM
timberwolf0122
Thanks
Just to be 100% when you check your fluid did you have the engine running and the transmission in Neutral? This is the correct way as the torque converter is engage this way and the fluid is pumping, otherwise you'll get an artificially high reading.
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
post #6 of 8 Old 02-23-2012, 09:03 AM Thread Starter
grpatter
Update here: @timberwolf : Yeah, that's how I've been checking it.
I went ahead and did a full flush of the fluid this past weekend so I could take a look. The fluid didn't *look* too bad (though that doesn't really mean much), and I didn't notice any shavings/flakes in the pan either. It may have been wishful thinking but it seems like it was *slightly* less audible for a couple days after the change, but it's definitely still there.
Not sure if this is helpful, but I had a friend with me the other day listen and he said he could feel some slight vibration in the passenger side nearish the front when it was making the noise that went away when it wasn't.
It almost feels like it's not fully engaging something (though the change is very very slight) and either less/more throttle gets it back into synch, if that makes any sense.
grpatter is offline
post #7 of 8 Old 02-23-2012, 10:39 AM
Brainwashed2566
Just curious, how many miles on the LJ?
2005 White LJ Mild Build = Fun Rig
2003 Ram 1500 5.9 Mag = DD
1997 Green XJ Bone Stock = SOLD
Brainwashed2566 is offline
post #8 of 8 Old 02-23-2012, 11:23 AM Thread Starter
grpatter
Just hit 75k
grpatter is offline
42rle , lj , tj , transmission
Need help for '03 TJ 42RLE noise issue. rpman TJ Wrangler Technical Forum 6 07-26-2011 09:38 AM
Sye for 42RLE? Tenshots1 TJ Wrangler Technical Forum 3 02-17-2011 09:35 PM
What is everyone using in the 42rle? ryan2022 TJ Wrangler Technical Forum 3 10-30-2009 08:56 AM
42rle -- > AW4? LOCKED UP TJ Wrangler Technical Forum 14 07-02-2009 07:45 AM
New A/t 42rle Fernandc TJ Wrangler Technical Forum 0 07-09-2003 08:18 PM
