41 Iroks on a Rubicon - JeepForum.com
post #1 of 37 Old 01-20-2010, 06:18 PM Thread Starter
jeepermom
I was thinking about putting 41 IRoks on my rubicon it has a 6.5 lift and
cro mo axles and 4:88s.
Has anybody ever put tires that big on a Rub, if so how did that work for you?
jeepermom is offline
post #2 of 37 Old 01-20-2010, 06:21 PM
TJunk
Good luck on the stock axle's. Takes work, but they will fit! Get a camcorder
I'm a huge fan of body lifts. In fact were I in your shoes, I would have gone for the 4" body lift and some 2" spacers on stock springs.
TJunk is offline
post #3 of 37 Old 01-20-2010, 06:46 PM
snwchris
snwchris's Avatar
Stock Rubi D44's and Balljoints won't really hold-up to those.
Also depends on how you are on the skinny pedal.
Stock D44's are good upto about 37's if semi built. 37 & up usually requires 1tons D60's to handle and take the abuse as well
Pretty tall vehicle 6" of lift & 41's... might want to consider dropping down to 4.5" springs and the Treks Hy-Line fenders.... they will easily fit 40's with 3-4" lift.
Chris
97TJ / Shaved D60-14B / 106" WB / 42's / Detroits
Front Leafs / Rear 4 Link
Rock Mafia Offroad & Hitman Offroad
snwchris is offline
post #4 of 37 Old 01-20-2010, 06:56 PM
DBLJ
DBLJ's Avatar
YOu will be breaking stuff left and right. If you are thinking anything over 37 then you need 1 ton axles.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #5 of 37 Old 01-22-2010, 01:08 AM
RogueSpear2023
You NEED one ton axles D44s are 1/2 ton axles they won't take 41" tires particularly heavy mud tires, you will be lucky if you make it out of your drive way with out breaking something. Plus your brakes, and steering won't handle it either. Even with upgrades D44s trussed and chromed can't take those tires but they could take 37s. The lockers in Rubicon won't take the stress from 41" tires either.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #6 of 37 Old 01-22-2010, 08:21 AM Thread Starter
jeepermom
big tires on a Ruby
Well thanks guys, I had found a great deal on some 41 IROKs,but I guess I'll just pass them up . I don't want to break anything.
I have 35s on it right now and she seems to handle that size just fine.
post #7 of 37 Old 01-22-2010, 08:24 AM
theducksguts
This seems like a horrible idea. Stick with some 35's. It is a good bet that a good driver with 35's can do the same as a good driver with 41's. Are you looking to crush cars? I don't understand all the hoopla about 37+tires. Costs to much to run them correctly.
Check out my
theducksguts is offline
post #8 of 37 Old 01-22-2010, 08:53 AM
Jake03TJ
I would go with the 40" MT/R's. I had them on my 1 ton Ford, and they were great on and off road.
ΜΟΛΩΝ ΛΑΒΕ
Jake03TJ is offline
post #9 of 37 Old 01-22-2010, 09:17 AM
Imped
Imped's Avatar
If you don't get it yet--
The difference between 35's and 40" tires might as well be analogous to the difference between a Geo Metro and a monster truck. You won't make it one wheelin trip on 40's.
OlllllllO
IndyORV
Imped is offline
post #10 of 37 Old 01-22-2010, 09:20 AM
Jeepme2
Not sure why everyone seams to think that you cant run a Dana 44 with bigger tires.Im running 42 IRocks and have done some extreme trails and have had no issues.Granted they have cromos.Just use some restraint with the gas.
Jeepme2 is offline
post #11 of 37 Old 01-22-2010, 02:48 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
tj rubi 44 isnt a true 44 anyway its a 44/30 hybrid.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #12 of 37 Old 01-22-2010, 09:59 PM Thread Starter
jeepermom
41 IROKS on a rubi
I thought that the gear on a rubi 44 was a little deeper than a regular 44.
Correct me if I'm wrong.
post #13 of 37 Old 01-23-2010, 09:30 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The Rubi 44 is not a 44/30 hybrid.
What do you call a D44 that uses 260 size u-joints which are smaller than the TJ and other late model D30s that use 297 u-joints?
Regardless, I would not run 41" tires on a D44.
Wheelin98TJ is offline
post #14 of 37 Old 01-23-2010, 10:03 AM
Beerman77
On the newer JK's yes they have a larger ring gear. TJ Rubi's use standard 8.5in D44 ring gears.
- 99TJ 4.0 4.5 RE springs, Clayton 5in LA stretch, GenRight Armor, 35x12.50 bfg mt, currie hp9 rear w/ 35 spline detroit, hp44 w/ arb and 4340 axles, k/n fipk, banks headers, warn xd9000i
- 04 Grand Cherokee Limited D/D K/N FIPK and Kolak exhaust
Beerman77 is offline
post #15 of 37 Old 01-23-2010, 10:10 AM
GOTROX
The ring gear on a Rubi 44 is Deeper. The weak points on Rubi axles for large tires are the outer shafts (D-30 equivalent) on the front, ball joints (IMHO good upt to 37" tires), and the factory locker.
I am running 37" tires on my Rubi. Chromo shafts, front and rear, CTM U-joints, 31 Spline outers on custom Unit Bearings, and a VancoPBS Big brake kit to stop them. My weak point is the factory locker. I have spares...
Ball joints can hold up if you drive with finesse. The Steering box is also being pushed quite hard. To make a jump to 40 or 41" tires, I'd swap to a Hi9, or HP-60 set up with ARBs and hydro steering.
GOTROX is offline
can i run 36" iroks outlawjosywales TJ Wrangler Technical Forum 15 07-23-2009 08:44 PM
36" iroks on d30 and d35... can they handle it.. jkm211 YJ Wrangler Technical Forum 5 08-22-2008 06:44 AM
36x13.5 iroks? z71offroader YJ Wrangler Technical Forum 14 01-01-2007 11:00 PM
? for people with IROKS McRoberts TJ Wrangler Technical Forum 6 10-16-2006 04:38 PM
SA and 36" Iroks? trance_junkie TJ Wrangler Technical Forum 11 06-26-2006 08:38 AM
