40K Fluid Changes!?! - JeepForum.com
post #1 of 2 Old 08-25-2010, 04:36 AM Thread Starter
sedanss
My 04 TJ 4.0L A4(non rubi) just hit 40K miles and i wanted to do some regular matiance and fluid changes but i have some questions(esipcally since i bought my jeep used and have no owners manual). What kinda tranny fluid should i use and how much should i need if i do a tranny filter change? What kind of fluid goes in the transfer case and about how much? What about the front and rear axle, what weight gear oil and about how much for each? Do you guys recomend synthetics or regualr dino fluids? What about coolant, i was gonna do a flush, drain, fill, can i use regualr green coolant or gm dex-cool? about how much coolant will i need for a flush and fill.
thanks for the info guys, need to pick myself up a chlitons when i see one at the parts store!
sedanss is offline
post #2 of 2 Old 08-25-2010, 05:41 AM
mdm
Farm Wheeler
http://www.jeepforum.com/forum/f9/tj-forum-faq-615132/
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
fluid , oil , change , maintenance , type , brand , tj , wrangler , rubicon
1989 4.2 transmission fluid leak, noob needs help checking fluid level. Sushorty22 YJ Wrangler Technical Forum 3 08-17-2012 11:09 AM
So I found out today... (low fluid and fluid leak with 32rh auto) Speed94 TJ Wrangler Technical Forum 43 08-26-2010 09:45 AM
YJ Transmission Fluid (MT90?) ,,,, metal piece when changing fluid GMC7000 YJ Wrangler Technical Forum 12 11-04-2008 07:11 PM
What do you guys use to change the tranny fluid and xfer case fluid?? Wheelman TJ Wrangler Technical Forum 11 12-15-2004 03:33 PM
Transmission Fluid, Diff Fluid, and Transfer Case markdonnell1975 TJ Wrangler Technical Forum 3 05-27-2004 01:27 PM
