new jeep owner, I think everything works fine on my 4 wheel drive and the light used to come on when I engaged but now it has stopped coming on. I've tried to get to it to check the bulb but can't find easy access. How do I get to the bulb? :brickwall
On my 2000 TJ, if you hold in the trip odometer button and turn on the key, the dash goes into diagnostic mode. All of the indicator lights come on in a sequence. Perhaps you could try that to see if it is just the bulb or not.
Might not be the bulb, could be the switch that sends the signal from the transfer lever. Otherwise, find someone with a real skinny arm to go up behind your dash?
Do you really need the light to put it in 4wd Id say F*#% it and wouldnt worry about it
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
