4 wheel drive light - JeepForum.com
post #1 of 13 Old 06-19-2010, 06:19 PM Thread Starter
jmpowie
4 wheel drive light
My 4 wheel drive light does not come on when I put it in 4. It could be a the bulb or what? Thanks
jmpowie is offline
post #2 of 13 Old 06-19-2010, 06:21 PM
dwilliams35
Yes, it could be the bulb. It could also be "What"... Get a dang voltmeter and go to looking for it, for pete's sake: it's pretty hard to diagnose something like that over the internet based on that.
dwilliams35 is offline
post #3 of 13 Old 06-19-2010, 06:49 PM
patduke90
There's a sender on top of the xfer case that blows out, not uncommon. Every TJ I've owned has had this problem.
patduke90 is offline
post #4 of 13 Old 06-19-2010, 06:53 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Wow!! He was just asking a simple question? And you my friend, are you sure you have a V6 in your Wrangler like stated in your profile?
GOLENJEEPTJ is offline
post #5 of 13 Old 06-19-2010, 07:02 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Ya...
DWILLIAMS35'S JEEP
Year & Model
Engine
4.0 V-6
Knuckelhead is offline
post #6 of 13 Old 06-19-2010, 07:31 PM Thread Starter
jmpowie
Thanks I will start there. dwilliams35 are you off your meds? you seem angry
jmpowie is offline
post #7 of 13 Old 06-19-2010, 08:26 PM
dwilliams35
No, not angry. And thanks for you guys pointing that out on the profile: a long, long time ago in a galaxy far, far away. I have no idea how I did that and hadn't noticed it. Fixed now: that's how things work, notice a problem, try to find out what's wrong, then fix it or ask for help.
Meanwhile, this is the kind of problem that before i started a thread on it, I'd be a heck of a lot further along: yes, it could be a bulb: check the dang bulb. Check power here, check power there. Sit back, drink a few beers, and decide if it's all that important to have a 4wd light anyway. If the answer turns up "yes", look a little longer, dig out the FSM, etc.: then come here and say "okay guys, I did this, I did that, and I'm drawing a blank: what would you guys look for next??" The question as posed was akin to "My jeep stopped running- do you think it could be out of gas?" Impossible to answer without some more information as to just what the OP has done to diagnose the problem: did you look at the gas gauge?
Yes, this could have been the bulb. Yes, it could have been "what". I guess we could just list each and every component involved in the relevant electrical circuit, including wire and connectors, and say "this could be it".
post #8 of 13 Old 06-19-2010, 11:46 PM
phillies4752
phillies4752's Avatar
dwilliams you need to relax man. He just joined the forum a couple of days ago... hes obviously new to this. Weren't we all new to this at one point? chill
phillies4752 is offline
post #9 of 13 Old 06-20-2010, 07:51 AM
dwilliams35
Well, i guess I wasn't new to this at one point: by the time the internet was started, I was already quite aware of how a VOM worked and it's proper application to the auto-electrics diagnostic process. I guess I'm just in the habit of basing such things on my own experiences: I would have phrased the question differently. Something like "My 4wd light is dead in the water: I'm a complete noob and don't have a clue what to start looking for or how to do it: any pointers?": I'd be all over helping in any way I could. But alas, today's society just wants the answers, not to learn how to figure it out....If I had asked that question when I was at that point, I would have had to react fast before the VOM hit me in the head...
post #10 of 13 Old 06-20-2010, 08:04 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
To the OP if you remove the plug from the switch on the t-case, stick a paper clip in there to connect both terminals with the ignition switch on, if the dash light comes on then the switch is bad, if not the bulb is likely shot. It is way more common for the switch to go out than for the bulb to blow though.
xjfever is offline
post #11 of 13 Old 06-20-2010, 12:26 PM
inglisleslie
Originally Posted by Knuckelhead View Post
Ya...
DWILLIAMS35'S JEEP
Year & Model
Engine
4.0 V-6
I am so confused. What custom work and engine did you swap in to get a V-6? Maybe open your hood once in a while and you will notice an inline setup!
I6 not V-6
inglisleslie is offline
post #12 of 13 Old 06-20-2010, 01:27 PM
dwilliams35
I6 not V-6
You're kind of running behind here.
post #13 of 13 Old 06-20-2010, 03:05 PM
Knuckelhead
AFSOC Retired
I6 not V-6
My responce was about DWILLIAMS35'S JEEP.
No wonder your confused...
4wd dash light , dash , light
4 wheel drive light problem tobrz YJ Wrangler Technical Forum 19 01-22-2012 12:10 PM
4 wheel drive light not working westmichjeeper TJ Wrangler Technical Forum 4 04-19-2010 06:45 PM
4 wheel drive light? jhoff TJ Wrangler Technical Forum 2 11-14-2007 04:47 AM
4 wheel drive light mandrews TJ Wrangler Technical Forum 4 11-06-2005 09:02 PM
4 wheel drive light jeepin94 YJ Wrangler Technical Forum 11 08-01-2003 02:43 PM
