4 Wheel Dive Low Not Locking In - JeepForum.com
post #1 of 8 Old 09-26-2012, 03:04 PM Thread Starter
snowmaninurface
So I was messing around with the gears today and when I got to the 4 wheel drive low it'll hit it but the gear won't lock in for some reason. The gear itself should be fine since I drove it in 4 low gear but it always just pops out after about 10 feet and I was wheeling about a week ago and it worked just fine. Help please I have no idea what's wrong with it.
snowmaninurface is offline
post #2 of 8 Old 09-26-2012, 03:08 PM
Ironhead
do you have a body lift?
have you adjusted your TC linkage?
Ironhead is offline
post #3 of 8 Old 09-26-2012, 03:09 PM
Zombi
You're out of adjustment is all.
I assume you have a body lift?
At any rate, get under the jeep, loosen the bolt on top of the adjustment rod, manually shift into 4-low at the t-case, move the handle into 4-low, tighten the adjustment bolt and you should be good to go.
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
post #4 of 8 Old 09-26-2012, 03:26 PM
Holm-z
Holm-z's Avatar
X2 on checking your linkage, it may be just enough out of whack to not fully engage. It doesn't take much time or elbow grease to fix it. Maybe like 10-15 minutes if your taking your time.
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #5 of 8 Old 09-26-2012, 03:36 PM Thread Starter
snowmaninurface
I haven't worked on my T-case before, so does the t-case skid have to come off? and where exactly is this linkage thing I looked but didn't find it
post #6 of 8 Old 09-26-2012, 03:40 PM Thread Starter
snowmaninurface
oh and it worked fine only a week ago so would it get messed up within that time?
post #7 of 8 Old 09-26-2012, 03:43 PM
freeskier93
No, you don't need to remove the skid. And yes, the linkage is a Rube Goldberg type contraption that easily gets messed up. Usually every couple wheeling trips I have to re adjust.
freeskier93 is offline
post #8 of 8 Old 09-26-2012, 03:45 PM
Holm-z
Holm-z's Avatar
http://www.jeepforum.com/forum/f59/t...please-813100/
here, this may help
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
4 wheel drive , help needed , jeep tj 98 , low range , transfer case
'08 JK-Do they have a locking steering wheel BillArf JK Wrangler Technical Forum 19 01-15-2010 10:47 AM
wheel locking up cableguy01960 YJ Wrangler Technical Forum 8 03-11-2009 09:16 PM
Wheel is locking? mac5551212 TJ Wrangler Technical Forum 5 07-24-2008 03:34 PM
4 wheel dive inspection(won't engage) rybicki YJ Wrangler Technical Forum 2 03-08-2008 10:58 AM
Need locking Wheel Nuts kamkuda JK Wrangler Technical Forum 18 09-01-2007 08:37 AM
