Quantcast 4" Suspension - Adding 1" BL, do I need a MML? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4" Suspension - Adding 1" BL, do I need a MML?
Old 07-01-2009, 10:30 PM   #1
cx300
I searched a little but could only come up with answers for people running stock suspension...
I have a 4" ProComp (yes I know...) Lift with the transfer case drop installed. I want to add the Performance Accessories 1" BL and am wondering what that will do to the TC Drop?
Do I need the MML? If I install it, can I get rid of the TC Drop, will my MX6 shocks be long enough etc...
Thanks in advance!
2004 Jeep TJ
www.GlobalResortHomes.com
www.BuyGlobalHomes.com
cx300 is offline   Reply With Quote
Old 07-01-2009, 11:42 PM   #2
tooofast
i dont think you'll need a MML when you do the body lift. I went the other way around and did the MML then the body lift. It helped with my vibration i think and my MM's were shot so it was great overall. I got mine from Brown Dog Industries (made in the USA)
To get rid of your tcase drop you'll need a CV drive shaft and a SYE ( slip yoke eliminator) or am pretty sure thats the only way to make the drive line long enough. not cheep but well worth it in the end to get the extra ground clearance.
I know people knock the pro comp short arm kits.. but hey i have done the big 3 in Moab with the same short arm kit and beat the snot out of it for couple of year and it let me run 35's when i did my 1" BL so it may not be the best out there but it works.. its better to wheel what you got than be a mall crawler and poke fun at others brands.
Cheers
Dave
4" clayton long Arm, with 5 inch rear stretch. 1" BL,35" BFG KM2muds, 1" MML from Brown Dog. Rear Dana 44 Locked with a Detroit also trussed on Alloy Shafts & 4 point triangulation. Rear disc conversion. AtoZ Cage. Rubicon OR241 4:1.. Up front a D30 locked with an ARB, Alloy Shafts and HD steering linkages. Clayton belly up and oil pan skids, Rokman tank skid, PSC Rocker Knockers, ORO Swayloc, Onbard Vita 450 and tank for fills and ARB compressor for the locker. Covered in dents.
tooofast is offline   Reply With Quote
Old 07-01-2009, 11:58 PM   #3
cx300
Cheers
Dave
Hey, thanks!
That is my plan to eventually get the 35s, SYE, Super 35 etc... I just figured why get it all at once!
I think that I am going to get the BL and see what happens, any idea about the MX6 shock length?
And I think that my lift is great! I have had ZERO issues with it (Did upgrade to Stage II and MX6 Shocks) I wheel it as often as I can (Busy student at UF [Go Gators!]) but not many trails in Central Florida, however I do head up north as often as I can.
Happy Wheeling!
-Travis
2004 Jeep TJ
Old 07-02-2009, 06:39 AM   #4
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Thanks in advance!
You didn't fill out your profile(auto or 5 speed?).If you have a 5 speed,you won't be able to shift into 2nd or 4th when your done.Your transmission and shifter has dropped and inch or more(t case drop).Then your going to raise the body up another inch.You don't need a MML with a BL,but since you already have a t case drop I would do it to avoid more problems.The PA BL has the much needed drop bracket for your t case shifter.You might get away with bending the tub to fix the shifter problems,if you have a 5 speed.Your shocks should be fine.
TheBoogieman is offline   Reply With Quote
Old 07-02-2009, 08:25 AM   #5
cx300
I fixed the profile, wasn't thinking when I filled it out!
so you are saying do the 1" BL, 1" MML, and keep the T-Case drop?
another question... if I went with a SYE and CV + BL what are my options then?
2004 Jeep TJ
Old 07-02-2009, 08:41 AM   #6
TheBoogieman
Demonic Jeep Freak!
You might be able to lessen or get rid of the t case drop.All Jeeps are different and you can see when it's all done.Do the BL,MML,remove the t case drop and see if you have any vibes.If you do,you might get away with dropping the skid with just a few washers.
Glock Forum
