4" RC lift and a SYE and CV - JeepForum.com
post #1 of 5 Old 12-06-2006, 08:40 AM Thread Starter
Daylan
I am looking to run the Rough Country 4" X-Series lift and would like to know if I should just go ahead and buy the SYE and CV or if the trans drop kit will eliminate vibs????? I do plan on doing some moderate off roading.
Daylan is offline
post #2 of 5 Old 12-06-2006, 09:19 AM
okeefe11
I drove my 4in lifted jeep for about a year with only transfercase drop. It didn't have vibes but I went through two sets of universal joints in the rear. I now have sye for a couple years and its much better on the u-joints. Though a buddy of mine had a four inch lift and the transfer case drop didn't get rid of his vibrations so he had to do the sye right away.
chris
2002 Jeep Wrangler X
4" suspension lift/currie anti-rock
33" Mickey Thompson Baja MTZ
Front & Rear ARB plus 4.56 gear
Front & Rear Warn Bumper w/9.5ti on Front
Poison Spyder Rocker Guards
okeefe11 is offline
post #3 of 5 Old 12-06-2006, 02:34 PM
beryl
i'd say go ahead and get it
beryl is offline
post #4 of 5 Old 12-06-2006, 04:11 PM
jedeason
I would get it if you have the money to spend. I ran the TC drop for a couple of months before I got mine. Had very minor vibes at take off but nothing drastic. Would pop out of second gear every now and then from gear shift hitting. You will also be happy to regain your clearance since you plan on doing some wheeling.
jedeason is offline
post #5 of 5 Old 12-06-2006, 04:45 PM Thread Starter
Daylan
Thanks a lot, I appreciate the help.
Daylan is offline
Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares planman JK Wrangler Technical Forum 44 01-31-2016 09:44 PM
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Wrangler Technical Forum 10 03-06-2010 02:43 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
