4" RC with 33s. What size bump stops? - Page 2 - JeepForum.com
post #16 of 18 Old 07-20-2011, 06:14 PM Thread Starter
mainliner
Super late reply here, but here's what I found out after contacting Rough Country:
Evidently their 2.2 shocks (the silver upgrade ones, not the standar white ones) have bump stops on the shocks, which they say makes bumpstops unnecessary. So far, so good.
I'm your huckleberry.
mainliner is offline
post #17 of 18 Old 07-20-2011, 06:36 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
any respectable shock manufacturer includes bumpstop inside the shock. they protect the shock, thats it. you don't use them instead of main bumpstops because the shock mounts will NOT hold the stress of the entire Jeep's weight plus gravity bashing into the shock mount repeatedly. Thats why shocks start leaking after you repeated beat on them with bottoming out, and eventually the bars pins break or the shock mount rips off the axle.
RC is well known for incompetence in this matter.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #18 of 18 Old 07-20-2011, 07:14 PM Thread Starter
mainliner
@Unlimited
The stops are not inside. The shock in your pic is not representative of the 2.2 RC shocks. There's a big chunk of rubber on the shaft. I'm making no claims as to its effectiveness, just noting it's existence, and that I've had no issues.
bump stop , bumpstop
What ext. bump stops are you using with 2.5" RC lift? webejpn01 JK Wrangler Technical Forum 3 09-01-2009 07:00 PM
Bump stops for 35s and +-6" lift 93jeepyj YJ Wrangler Technical Forum 2 07-26-2009 08:00 AM
What size bump stops? daaaaaan YJ Wrangler Technical Forum 1 03-26-2007 10:41 PM
What size Bump Stops CAPCDT388 TJ Wrangler Technical Forum 1 02-07-2006 05:00 PM
REBB Rear bump stops- What size bolts? SoTX Hunter TJ Wrangler Technical Forum 6 12-29-2005 08:29 PM
