4" RC with 33s. What size bump stops? - JeepForum.com
post #1 of 18 Old 04-20-2010, 08:50 PM Thread Starter
mainliner
I've had a hard time finding definitive info on correct bump stop size.
I have the 4" RC series II lift with the 2.2 shocks. I'm running 33s and have a ton of clearance. The 10 year old stock bump stops are so rotted they remind me of those coolers Kwicky Mart sells for $2. In a word, useless.
Any suggestions for replacements?
mainliner is offline
post #2 of 18 Old 04-20-2010, 09:27 PM
Jeepzcb09
same situation... cannot find a "real" answer! Could i get away with pucks on the spring perch? I do have a 2in BB laying around, any ideas i could do with that?
1998 TJ Sport : Rough Country, MetalCloak,KC, Goodyear, Crager, Alpine, AtoZ, Currie, Aussie
Believe.
Jeepzcb09 is offline
post #3 of 18 Old 04-20-2010, 09:49 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
your stock bumpstops aren't being used because you're not reaching them. the 4" lift shocks are acting as bumpstops themselves (not good).
heres a chart to help:
http://www.jeepforum.com/forum/f9/bu...points-734737/
helps a lot to know the extended & collapsed length of the shocks your running...
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 18 Old 04-20-2010, 10:09 PM Thread Starter
mainliner
Trust me, they were well used before the lift. I haven't pushed the flex enough since to get to the not good point, thankfully.
Thanks, I'll have to get RC on the phone tomorrow to get me the lengths of the shocks so I can use the chart. Maybe someone with the same shocks knows their length, so I can finger this out tonight?
post #5 of 18 Old 04-20-2010, 10:40 PM
jdhallissey
Your between 2 to 2.5 inches. I have 2 in pucks in my lift. I didn't put them in since I was going to get the air bump style but ran out of money then got lazy and didn't put mine in yet lol. Maybe this week I will toss in my 2in pucks.
jdhallissey is offline
post #6 of 18 Old 04-21-2010, 07:07 AM
Unlimited04
got a tape measure? you can figure it out yourself
Useful Write-Ups:
Funny:
post #7 of 18 Old 04-21-2010, 01:07 PM
Jeepzcb09
so with my 4in lift would throwing hocky pucks on the spring perch work?
Believe.
post #8 of 18 Old 04-21-2010, 01:15 PM
Unlimited04
you need to attach them somehow.
Useful Write-Ups:
Funny:
post #9 of 18 Old 04-21-2010, 01:15 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Nobody here can tell you for sure.
You need to crawl under your Jeep with a tape measure and figure it out.
1. How much room for uptravel do your shocks have?
2. How much uptravel do your tires have before they contact sheet metal?
3. How much room is currently between your axle and the bumpstops?
Measure all the above and you'll know how much longer or shorter your bumpstops need to be.
If #1 or #2 are less than #3, you need to extend the bumpstops until #3 is less than both #1 and #2.
Wheelin98TJ is offline
post #10 of 18 Old 04-22-2010, 12:35 AM
mudb8
want it rite or rite now?
mudb8's Avatar
just measure as the above pic shows...
If you can tell me the collapsed shock length, I can tell you what you need, but you'll have to pull the lower end off the mount and measure it anyhow.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #11 of 18 Old 04-22-2010, 05:04 AM
1CleanTJ
1CleanTJ's Avatar
yep, shocks and brake line become limiting factor with the RC 4" without bumpstopping. my brake line is pretty tight at this pic checking out flex
another thing if you didnt get arms with a flex joint on them, the fixed arms put alot of stress on your lower CA mounts
over all flex isnt to bad though
<-- CLICK !!! AND SHARE
1CleanTJ is offline
post #12 of 18 Old 04-22-2010, 06:30 AM
Unlimited04
CleanTJ, post a pic of the spring perch on the passenger side, showing the bumpstop cup & jounce bumper. i bet the jounce bumper isn't even compressed, and with those brake lines tight you can't turn & flexing at the same time....
Useful Write-Ups:
Funny:
post #13 of 18 Old 04-22-2010, 06:34 AM
rideraa
For reference, when looking at the measuring diagram (pic) I see the point as the bottom flange of the steel cup.
Is that correct, and not the bump stop end ??
nice flex shot 1cleanTJ BTW
"CHEAP HEAP" TJ, 4.0, 32rh, 231, built D44's, 37s etc.
"George 4man" CJ7, 304, 727, D300, C/O rear w/ stretch, built D44's (4 now) on pane :).
rideraa is offline
post #14 of 18 Old 04-22-2010, 06:42 AM
Unlimited04
read mudb8's thread....the jounce bumper will fully compress, its there just to "cushion" the impact.
Useful Write-Ups:
Funny:
post #15 of 18 Old 04-22-2010, 10:34 AM
rideraa
thanks .. makes sense
rideraa is offline
bump stop , bumpstop
What ext. bump stops are you using with 2.5" RC lift? webejpn01 JK Wrangler Technical Forum 3 09-01-2009 07:00 PM
Bump stops for 35s and +-6" lift 93jeepyj YJ Wrangler Technical Forum 2 07-26-2009 08:00 AM
What size bump stops? daaaaaan YJ Wrangler Technical Forum 1 03-26-2007 10:41 PM
What size Bump Stops CAPCDT388 TJ Wrangler Technical Forum 1 02-07-2006 05:00 PM
REBB Rear bump stops- What size bolts? SoTX Hunter TJ Wrangler Technical Forum 6 12-29-2005 08:29 PM
