#1 | |
4 lo wont engage
i went off road tonight and i was going through some deep water/mud and didnt wanna get stuck so i engaged 4hi but that wasnt good enough so i went to 4lo and it wouldnt engage. i finially got unstuck and retried usin 4lo out the mud wouldnt work what would cause my 4hi to work but not 4lo??
#2 |
have you done a search, if not do one many people ask this question
did you look under your jeep and check the linkage?
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada |
#3 |
the linkage? not to offend you, but a pansy ar$e pull on the shifter lever?
[SIZE=2][COLOR=Navy]MK Motorsport & Fabrication [/COLOR][/SIZE] |
#4 |
what are you talking about?
#5 |
no i wasnt the only one to try putting it in 4lo. where is the shift linkage located on the jeep??
#6 | |
I was responding to the original post, not to yours even though it looked like i was questioning you.... ![]()
#7 |
did you put tranny in neutral?
If you havent already tried this, try putting your tranny in neutral and make sure your jeep is rolling at least 3 miles an hour either in forward or reverse when you do it and then yank your transfer case shifter back into 4lo, should work...hope this helps.
Curlam
98 5.9 ZJ-stock for now and 04 rubicon with toys by troy bumpers both soon to be lifted |
#8 |
Standard operation for going for getting to 4 low:
1) slow down to 5mph or stop 2) *put transmission into neutral 3) move transfer case shifting lever to 4 low * on my 02 pushing in the clutch isn't good enough, has to be in neutral to engage or disengage the 4 low. hope that might help.
Green 2002 TJ Sport |
#9 |
thanks for all the responses but no luck
#10 |
iight i went and looked and there was a lot of debris where the 4wd shifter was. now that i know its bent what can i do to bend it back or do i have to get a new shift link and how much is that??
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
