4 Link Geometry Question - Page 2 - JeepForum.com
post #16 of 49 Old 05-02-2010, 02:59 PM
nriver
2011 JK Wrangler
With the PP brackets. You can decide where you want them on the frame. Then the rest becomes self evident.
I did a bunch of the calculator stuff, then threw it all out the window and placed the brackets on the frame where they wanted to go and did the arms to match.
At about full stuff the arms hit the frame. But the front axle hits the engine and the rear axle hits the tub, and the upper arms hit the tub....
Why do I post here?
nriver is offline
post #17 of 49 Old 05-02-2010, 05:53 PM Thread Starter
Dogman
Dogman's Avatar
Originally Posted by thrca View Post
Dogman, do you have the 4Link Calculator spreadsheet? It's quite convenient for quickly getting a glance at arm lengths at stuff and droop and graphing out things without using an eraser and a ruler. Just a thought.
Stolen from POR
http://highvibesoffroad.com/drawings/4BarLinkV3.0a.zip
I have played around with them, but I like drawing it out. I'm actually about a year out on this project, so I started measuring and drawing more as a learning tool.
I'm starting to think I'll spend the money on brackets just because I want to do things right. I've done some decent fabrication, but making brackets can be a real pain.
I'm starting a develop an opinion on theory vs. reality here
John 3:17
Dogman is offline
post #18 of 49 Old 05-04-2010, 12:07 PM Thread Starter
Dogman
Dogman's Avatar
Ok, I broke down and started using the Calculator Now back to theory, I need some help with the numbers. Mainly what kind of anti-squat number I'm looking for?
John 3:17
Dogman is offline
post #19 of 49 Old 05-07-2010, 07:46 PM
slafferty
i'm just goings to buy claytons brackets mount them in claytons location and built the arms to fit. seems like it would save the headache
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #20 of 49 Old 05-07-2010, 08:38 PM Thread Starter
Dogman
Dogman's Avatar
Dogman is offline
post #21 of 49 Old 05-25-2010, 03:24 PM Thread Starter
Dogman
Dogman's Avatar
Well, I'm updating this for myself and anyone else who might stumble upon this thread. I have been going crazy thinking about brackets. I've been mocking stuff up with cardboard and searching for pre-made brackets. I hate to buy stuff when I can make stuff, but this is one of the times that I'm realizing how much of a pain it is to make nice brackets for this and how much time/effort it will save to buy.
I found these Kore brackets that are nice and cheaper ($215/pr) than the Poly brackets:
John 3:17
Dogman is offline
post #22 of 49 Old 05-25-2010, 07:40 PM
nriver
2011 JK Wrangler
Nice, looks about the same. Saving time on this part is not a bad thing, IMHO.
Why do I post here?
nriver is offline
post #23 of 49 Old 05-25-2010, 07:54 PM
Imped
Imped's Avatar
Those Kore brackets look awesome. I'd say go with those.
OlllllllO
IndyORV
Imped is offline
post #24 of 49 Old 05-26-2010, 01:59 PM Thread Starter
Dogman
Dogman's Avatar
Well, it looks like there is no provision for the brake/fuel lines to pass through the Kore brackets (as seen on the Poly brackets). The difference in cost is not worth having to cut/flare/route those lines around the brackets.
Poly:
John 3:17
Dogman is offline
post #25 of 49 Old 05-26-2010, 08:41 PM
nriver
2011 JK Wrangler
IIRC, I ended up routing mine on the top of the frame/bottom of the tub. Not sure that is totally an issue.
I will say, routing all the lines is an issue, but behind the mount, not an issue. IMHO.
Why do I post here?
nriver is offline
post #26 of 49 Old 05-27-2010, 08:50 AM Thread Starter
Dogman
Dogman's Avatar
I appreciate the input. I was reading your thread yesterday trying to see what other kind of issues I may run in to (I have more time than money right now ). Fortunately, I just have the fuel/brake lines to deal with and not the evap stuff.
I'm also trying to figure out the dimensions of the poly brackets. Would you possibly be able measure the distance from the lower link bolt hole to the front of the mount for me? My guess is about 4". If so that would mean my lowers will be in the 26-27" range.
John 3:17
Dogman is offline
post #27 of 49 Old 05-27-2010, 10:08 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Poly:
Nothing against Poly because I use a lot of their stuff, but I'd strongly recommend against that routing. If you have any issue with a line, it's going to be harder to deal with. I always route them around and on top of the frame and then back down. Besides, you have to follow the upper down with the brake line and typically an air locker line so those exit in front of or beside the upper mount.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #28 of 49 Old 05-27-2010, 01:36 PM Thread Starter
Dogman
Dogman's Avatar
Sounds like I have a little more homework to do
So whichever brackets I go with, the hard line will pretty much terminate at the bracket and then a soft line will route on the upper arm down to the T on the axle?
I'm actually glad that I have time to work through all this stuff and ask questions ahead of time.
John 3:17
Dogman is offline
post #29 of 49 Old 05-27-2010, 10:00 PM
nriver
2011 JK Wrangler
I will try and take some measurements this weekend. Lots to still do under there.
Why do I post here?
nriver is offline
post #30 of 49 Old 08-04-2010, 08:03 PM
snowrydr01
any updates what happened with this?
snowrydr01 is offline
4 link , arms , link , mid , suspension
track bar geometry combsj YJ Wrangler Technical Forum 3 01-03-2010 04:32 PM
To link or not to link that is the question? yjcrawlr YJ Wrangler Technical Forum 1 03-30-2008 04:52 PM
Proper geometry 4point TJ Wrangler Technical Forum 11 04-22-2007 01:43 AM
Driveline geometry question... Tom400CFI YJ Wrangler Technical Forum 12 10-11-2006 05:29 PM
soa steering geometry? ErikJordan YJ Wrangler Technical Forum 3 09-18-2002 01:30 PM
