4" lift...setting rear pinion anlge questions - JeepForum.com
post #1 of 3 Old 08-15-2010, 08:20 PM Thread Starter
domano 68
I will be putting on a 4" lift on my rig soon and wanted to understand how to set the pinion angle and line it up properly with the output shaft of my transfer case. Not finding much with search option. I will be usin Rubicon Express upper rear adjustable control arms and a JB Conversions SYE.
A diagram would be great or any links to any detailed posts on this subject. I've not done a lift before but willing to learn and need all the info going into this as possible. TIA!
2005 Wrangler Unlimited
domano 68 is offline
post #2 of 3 Old 08-15-2010, 11:51 PM
Ggg
With a SYE you will need a new CV driveshaft. When setting the pinion for this style shaft you want to point the pinion directly at the SYE yoke.
Ggg is offline
post #3 of 3 Old 08-16-2010, 12:11 AM
Imped
Imped's Avatar
A much simpler way to put it--the pinion angle and drive shaft angle need to be inline. You should be able to draw a straight line down the middle of both.
OlllllllO
IndyORV
Imped is offline
setting pinion angle on RE 4.5" lift 03rubiconMG TJ Wrangler Technical Forum 1 08-11-2008 07:51 PM
Help setting 8.8 pinion angle Airborne4X4 TJ Wrangler Technical Forum 2 05-25-2008 10:39 AM
Rear trackbar questions and 3" lift q's thebulkinator TJ Wrangler Technical Forum 2 05-11-2005 06:31 PM
Setting Pinion Angle mking7 TJ Wrangler Technical Forum 5 09-18-2003 01:56 PM
setting pinion angle Bob J TJ Wrangler Technical Forum 2 07-15-2002 02:47 PM
