4" lift, 2" bl, and 35 pictures? - JeepForum.com
post #1 of 10 Old 07-05-2010, 09:58 AM Thread Starter
Daniel20
will someone post a pic of a tj with 4" susp and 2" bl and 35's. I've looked for one and havent been able to find one and the pic on the what does my jeep look like with lift sticky won't download.
Daniel20 is offline
post #2 of 10 Old 07-05-2010, 10:02 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
GOLENJEEPTJ is offline
post #3 of 10 Old 07-05-2010, 10:06 AM
BlueRubiconrich
It's not just about a lift and big tires you will need to change the grears in the Axles. And Why put gears in a Dana 35, go with a Dana 44 or 8.8 rear.
It's about the whole package You are running a 4 banger do your homework.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #4 of 10 Old 07-05-2010, 10:13 AM
Benderff
Benderff's Avatar
That link should help. Try looking in the Picture request section also since your not needing anything technical.
Benderff is offline
post #5 of 10 Old 07-05-2010, 10:25 AM Thread Starter
Daniel20
I have 4.88's waiting to be installed along with everything else thats needed to run 35's on my jeep and I'm working on getting a crashed ford ranger just for the 8.8, so I geuss I have done my homework I'm just debating on leaving the 2" bl i have off and running 35's on the 4" susp with 3/4" spacers up front
Daniel20 is offline
post #6 of 10 Old 07-05-2010, 10:27 AM
Imped
Imped's Avatar
That's plenty of room for those tires. What's the problem?
OlllllllO
IndyORV
Imped is offline
post #7 of 10 Old 07-05-2010, 10:28 AM
t-bird
eww why out of a ranger? they are even narrower than the explorer 8.8s
JEEP
t-bird is offline
post #8 of 10 Old 07-05-2010, 10:31 AM Thread Starter
Daniel20
So I shouldn't need the BL for 35's?
Daniel20 is offline
post #9 of 10 Old 07-05-2010, 10:33 AM Thread Starter
Daniel20
Is there anywere to order an 8.8 from thats bolt in for a tj?
Daniel20 is offline
post #10 of 10 Old 07-05-2010, 10:51 AM
t-bird
yes. Complete Ford 8.8" Rear Axle Assembly Jeep TJ Ready to Bolt In Axle Swap
JEEP
t-bird is offline
lift , suspension , picture , request , bl , body lift , 35
Looking for pictures of a YJ with 6" spring lift or SOA lift Dwayne93YJ YJ Wrangler Technical Forum 1 05-21-2008 06:19 PM
Do I already have a lift kit? (pictures) veestan YJ Wrangler Technical Forum 5 04-23-2008 10:14 AM
lift pictures... wrangler2007 TJ Wrangler Technical Forum 4 12-23-2006 07:14 AM
SOA Lift Pictures! xeon YJ Wrangler Technical Forum 33 08-09-2005 01:36 PM
Lift Pictures FOoLieo TJ Wrangler Technical Forum 8 03-05-2005 10:59 PM
