4"lift with 1"body lift with 33s - Page 4 - JeepForum.com
post #46 of 62 Old 05-06-2013, 11:54 PM
1998tjsport
Originally Posted by JasonMHorn View Post
Why is that?
From first hand experience they tend to sag. I run a 3inch Savvy/Currie setup and my good friend has a TJ with a 3inch RC with a 1.25 BL. We sat at the same height in the front and his rear was .5" lower than mine.......He now has a bumper, winch, and a tire carrier and sits slightly lower in the front than my stock bumpered TJ. It took about a year for it to sag how it did but it did sag. On the bright side though RC did say they would send him a new kit ....so it seems they will stand by their product.
WTB INCA GOLD HALF DOORS PM ME
Current-
2003 INCA GOLD TJ Rubicon 5 speed 3inch Currie/Savvy Lift, JKS Discos, 305 KM2s
Build Thread
Past-
1994 Grand Cherokee 5 SPEED 3inch lift, tj bumper, 31x10.5s, wheel spacers, rhino liner, ect.....
1998 TJ Sport 5 Speed 31x10.5s, completely murdered out, and a short throw haha (miss that jeep)
1999 TJ SE 5 Speed (ls swap that became a part-out due to excess frame rot)
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
1998tjsport is offline
post #47 of 62 Old 05-07-2013, 04:36 AM
JasonMHorn
I appreciate the info. And hopefully they'll stand by it if it does end up occurring.
JasonMHorn is offline
post #48 of 62 Old 05-07-2013, 02:30 PM Thread Starter
Miller16
so i ordered mylift today, not 4" or skyjacker or zone, but rough country....3.25" and then ill be deciding on 1" or 1.25" bl
Miller16 is offline
post #49 of 62 Old 05-07-2013, 02:38 PM
Ironhead
Ironhead is offline
post #50 of 62 Old 05-07-2013, 03:55 PM
mike_dippert
mike_dippert's Avatar
That extra .25 won't be noticable driving. But it may make a world of difference with clearance. Go for the 1.25.
mike_dippert is offline
post #51 of 62 Old 05-07-2013, 06:55 PM Thread Starter
Miller16
well i be able to fit 35s after i get the bl?
Miller16 is offline
post #52 of 62 Old 05-07-2013, 07:07 PM
mike_dippert
Originally Posted by Miller16 View Post
Will i be able to fit 35's after I get the BL?
35's will work with 4" and up without anything fancy. As long as your springs stay above 2.75" of lift, and you use a 1.25" lift, you shouldn't have a problem. Every situation is a little different though, and I have no idea how the 3.25 springs hold up long-term. Don't forget to adjust your bumpstops and steering stops accordingly.
post #53 of 62 Old 05-08-2013, 12:17 PM
bdub1285
I run 35's no problem with 3" suspension and 1.5" body lift. I do have flat fenders though.
2001 Jeep Wrangler Sport, 4.5" lift, Front/Rear ARB Air Lockers, Dana 30/Dana 44 axles with alloy shafts, 4.56 gears, Weld in Roll Cage, 35x12.50 Cooper Discoverer Tires
bdub1285 is offline
post #54 of 62 Old 05-08-2013, 12:29 PM
mike_dippert
That's 4.5"...
I could slightly rub 33's on the outer part of the flare with a 4" lift before my BL. I have 2" bump stop extensions.
post #55 of 62 Old 05-08-2013, 08:39 PM Thread Starter
Miller16
How would I make my bump stops work proabably ans steering stops?
Miller16 is offline
post #56 of 62 Old 05-09-2013, 04:44 AM
mike_dippert
When you get the 35's, leave the springs out and jack up each tire until it hits something. Take out the little rubber inserts from the bump stops. Add a spacer to the axle spring perch so the the tire doesn't contact anything.
Reinstall the little rubber bumpstops and springs.
Steering stops are just a bolts on the knuckle. They keep the wheels from turning too far. Like if you're tires hit the swaybar when turning at full articulation.
post #57 of 62 Old 05-09-2013, 06:32 AM
Ironhead
I was running 2" springs and a 1.25" bl with 35's, no problem at all, no rubbing. currently running 3" springs up front due to a winch resting on my bumper.
currently running more down travel than uptravel until I relocate my shock mounts and raise the fenders.
you dont need 4"+ lift to run 35's
Ironhead is offline
post #58 of 62 Old 05-09-2013, 08:18 AM
mike_dippert
I guess I assume there's not enough uptravel. Everybody has a different take on it though.
post #59 of 62 Old 05-09-2013, 08:24 AM
mannyspd1
Currie's instructions for their 4" kit say that when used in conjunction with a 1" bl, their kit is good for 35" tires.
98 TJ Chili Pepper Red, 5-speed
mannyspd1 is offline
post #60 of 62 Old 05-09-2013, 08:58 AM
sjones26573
Ok. You can also fit 35's on 2" lift. You will just have no travel.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
body lift , tj
