Quantcast 4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft?
Old 05-07-2003, 09:03 PM   #1
ECUSAE20
If I do a 4" Skyjacker suspension lift and a 2" body lift will I need a slip yoke eleminator/rear driveshaft?
Skyjacker says it will be unnecessary with the there suspension lift but does body lift matter?
Does a body lift make the slip yoke/driveshaft come into play?
It will be going on a 01' Wrangler SE 2.5L.
Preferably with 36's.
ECUSAE20 is offline   Reply With Quote
Old 05-07-2003, 10:42 PM   #2
Dacaur
2008 MK Patriot
body lift doesnt affect the drivetrain, just the, uhhh, body...
Dacaur
99 WJ Laredo
2.5" Budget boost, 265/75/16 tires, K&N air filter
www.dacaur.com/jeep.html
Past Jeeps:
1992 YJ 4.0, 5 speed 6", lift 33's
1992 XJ 4.0, auto, 3" lift, 31's
1999 XJ 4.0, auto, 3" lift, 31's
1985 XJ 2.5, 5 speed, no lift, 255/70/15's
Dacaur is offline   Reply With Quote
Old 05-07-2003, 11:22 PM   #3
macb
body lift does not affect suspension angles, but 4" may require
a SYE or at least a few washers to drop the t-case. Or a MML
would help if you get the vibes. Every jeep is a little different when
it comes to vibes with lift. You will need to consider a tcase shifter
bracket if one does not come with your kit.
HTH
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah: [URL]http://www.sajeeps.com[/URL]
[url=http://www.cafepress.com/H2RT]No Bling - H2 Recovery Gear[/url]
Bob Supplee:supplee@ionet.net or (405) 799-8977
Stu Olson's great jeep resource site: [url=http://www.stu-offroad.com]www.stu-offroad.com[/url]
macb is offline   Reply With Quote
Old 05-08-2003, 09:32 AM   #4
CJEli
I am at about 3"s of suspension lift. I have a 1" MML and have my T-case dropped about 1/2" and still have some vibes. I have a D44 5 speed which is more prone to vibes though. You "should" be ok with either a 2" T-case drop or a 1" and a 1" motor mount lift.
However, if you are planning on running 36s on a D35, I would worry about that first.
-Eli
00 Yellow TJ Sport, Locked, on 35s
My Junk
CJEli is offline   Reply With Quote
Old 05-08-2003, 11:16 AM   #5
macb
good point - that is a lot of rubber to be turning on a D35...
you should at least put in a super kit - or look at an upgrade
axle. Unless of course this will be a 'street jeep' where looks
are all that counts. Plus you will be looking at a gearing upgrade
Old 05-08-2003, 12:18 PM   #6
sivarock
I have 4.5" and yes, I needed a SYE and C/V Driveshaft. In my opinion they make all the difference in the world. Other not often mentioned side effects are decreased power and gas mileage, both of these will suffer without a SYE.
I agree with Mcgawb, 36's are allot of rubber for this set up, I personally wouldn't suggest it. Some 32's or maybe 33s would be your best bet.
sivarock
2002 TJ 4.0 Sport 5 Spd. 4.5" Rubicon Express Lift, 33X12.50 BF Goodrich MTs on 15X10 Mickey Thompson Classic IIs, SYE & Tom Woods custom driveshaft, Aftermarket stainless hinges and mirrors.
sivarock is offline   Reply With Quote
Old 05-08-2003, 12:26 PM   #7
ksuyellowTJ
I have a 4.0 with a auto and I'm only runing 33's and I still broke a axle shaft a few weeks ago. I have yukon shafts and a detroit in my 35. It would suck to drive 36's on street with a 2.5L. Mike
00 TJ 4.0L, auto Solar Yellow
F/R BulletProof Bumpers
4.5" RE Super Flex
33x12.5x15 MTR's on black wheels, 4:10 gears with a Detroit in the rear with Yukon axle shafts
Front Lock Right
Poison Spyder dana 30 rock ring
soon aw4 or a 700r4 and maybe a dana 300
ksuyellowTJ is offline   Reply With Quote
Old 05-08-2009, 08:58 PM   #8
sil240x1234
yellowtj is right i have 35x15.50 sx's on my yj with a 2.5l, no gears yet until the new axle goes in and it is fine around town, but getting up past 2nd gear is a pain and i can only hit about 55mph on the highway, and thats using 3rd gear and then once up to speed i can put it in 4th (my highway gear). I would not recomend that big of tire with no gears.
93 yj 2.5L 5-speed, 4" superlift susp., pro comp 9000 shocks, 2inch body lift, 35x15.50x15 tsl sx on 15x10 MT classic 2's, JKS disconnects, dynamax cat back, hurculined tub.
sil240x1234 is offline   Reply With Quote
Old 05-08-2009, 10:06 PM   #9
ballallday89
I have 4 inch skyjacker, and 1 inch spacer under the tranny so i dont need SYE. saves me a lot of money. But Like the others are saying, please consider doing maybe a 3.5 inch lift with 33 inch tires. 36 inch tires are gunna break you jeep.
Christian Jeep Member - 56
ballallday89 is offline   Reply With Quote
Old 05-08-2009, 10:13 PM   #10
RnEmOvr
Never Forget
RnEmOvr's Avatar
did it ever occur to you guys he may upgrade the rear axle? why cant people just answer the question at hand and not go off topic complaining about other stuff, hell i suprised we made it 9 post and noone said "dont do a 2" BL they ugly and unsafe blah blah"
OP as stated the BL will not effect the driveline, you could have a 8" BL and not need to touch the driveline (would have lots of other issues but thats another thread) chances are the 4" lift alone will net you the need for a SYE but you could get by with a TC drop, i did till i put my SYE in. and before someone says it, you DO NOT need a MML for the BL, i ran a BL for years without a MML.
and just cause i can here is 4" suspension with 2" BL and 33s both with and with out fenders
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 05-08-2009, 10:16 PM   #11
mikeb683
should prolly do it when u got the loot
mikeb683 is offline   Reply With Quote
Old 05-08-2009, 11:12 PM   #12
Dacaur
2008 MK Patriot
What are you on about? His question was answered in the first 2 replies (back in 2003...) before anyone "went off topic"... If I stated that I was going to do something that others thought might be silly, I would sure be happy if people gave me advice about it after answering my original question, which is what happened....
Dacaur
99 WJ Laredo
Past Jeeps:
Glock Forum
