4 Inch Skyjacker Question - JeepForum.com
post #1 of 3 Old 07-25-2005, 10:14 AM Thread Starter
samger2
I have a 4 inch skyjacker that me and a buddy installed about 4 months ago on my 97 TJ. The sway bar links are just barely off the frame...I mean I can't even fit my pinky finger between the top of the sway bar links and my frame...this isn't normal is it? If I did any wheeling I'm afraid they would smack the frame!!
Thanks...
Sam
samger2 is offline
post #2 of 3 Old 07-25-2005, 10:18 AM
97TJGUZZY
97TJGUZZY's Avatar
when you installed the kit did you redrill your front trackbar hole or install a new adjustable front trackbar? It sounds like if you did you didnt drill it far enough over of you didnt adjust your trackbar enough to center the axle back...If you look at the other sice, the swaybar should be farther than normal. THe entire swaybar has actually shifted towards the drivers side because of the swing of the trackbar.
The best solution to this is an adjustable front trackbar...but I have seen bandaid solutions that use clams to hold the swaybar centered in its bushings....
For info on outdoor adventures in South Carolina check out
97TJGUZZY is offline
post #3 of 3 Old 07-25-2005, 02:08 PM Thread Starter
samger2
We drilled a new hole. It didn't come with a new trackbar. One side seems a little bit closer to the frame...but hardly noticeable.
Sam
samger2 is offline
skyjacker 4 inch or something else tyvan JK Wrangler Technical Forum 4 01-02-2010 01:23 PM
Skyjacker 2 inch to 3 or 4 inch lift cush8124 TJ Wrangler Technical Forum 7 10-28-2009 06:26 AM
2 inch skyjacker lift Drjones266 TJ Wrangler Technical Forum 1 04-11-2004 07:16 PM
2 Inch Skyjacker Lift Drjones266 TJ Wrangler Technical Forum 1 04-11-2004 02:14 PM
skyjacker monoliniar 6 inch kit dukeboy1984 YJ Wrangler Technical Forum 3 01-17-2003 11:30 PM
