4 inch ProComp + 1 BL and 37's...(pics)!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4 inch ProComp + 1 BL and 37's...(pics)!!
Rough Country 2.5" long arm suspension systemDan's 15% Birthday Sale!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-30-2007, 06:52 PM   #1
Wup This
It's done for now...
I have to take off the Spare and redo the exhaust tip and get center caps and regear and adjust the tcase linkage and....well a million other little things but it's done.............for now
4 inch ProComp Stage 2 with MX6 adjustables.
ProComp triangulated 4 link convertion for the rear which eliminated the rear track bar.
1" PA BL to clear the 37x12.50.17's on Soft 8's with 4.5 inches of BS.
To be honest I don't think I even need the little Tcase drop so it might come off. DS angles are right on, no vibes. I need to regear but it's not killing me right now and the brakes are far more effective than I ever thought they'd be.
The tires clear lock to lock without any spacers in the stops and I went with the BS of 4.5 with a little helpfull advice from Jerry B..(thanks Jerry, I really like the way the rims and tires tuck into the Jeep too).
To the guy at 4 wheel parts, NTB, a few of you on here, and almost every other "Jeep Guy" around me.......THE 37's FIT PERFECT
Poser garage shots, I know and it's not real clean but it's the best I could do with how much I work and how short the daylight is
98 XJ, Pearl Green, 4.5" lift, 32's Daily Driven. BEAT IT! BREAK IT! FIX IT!
Wup This is offline   Reply With Quote Quick reply to this message
Unread 11-30-2007, 08:26 PM   #2
silvergreentj
get her dirty. and oh, it looks smooth
Slow Life-02TJ-35 Trepadors
98TJ-33 Mtzs
Low Life-87 slammed e30
silvergreentj is offline   Reply With Quote Quick reply to this message
Unread 11-30-2007, 09:22 PM   #3
badoosh27
looks really good, i guess its the fact that its an unlimited but the tires look smaller than 37's. i'm not doubting you, just looks wierd. you need some outside pics and like he said get it durty
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
[url]http://www.cardomain.com/ride/2634280[/url]
badoosh27 is offline   Reply With Quote Quick reply to this message
Unread 11-30-2007, 10:34 PM   #4
chandlerr
chandlerr's Avatar
it might be that they're 17" rims but yeah they do look smaller than 37's
2004 Black Rocky Mountain Edition, Clayton 4 Linked w/ 4" Pro Comp Springs, 37" Iroks (lost to Mexico. RIP Krystal)
2006 Black LJ Rubicon, mostly stock with 33's... soon to change
chandlerr is offline   Reply With Quote Quick reply to this message
Unread 12-01-2007, 12:08 AM   #5
CrawlinLJ
Do not be surprised if you rub your tires. turning is one thing but dont forget to check the compression at the wheel wells. I have a 5.5" RE with 37" and I just clear upon full compression. FRont is perfect but my rear tire will catch by 1/4" in front of the tire on the body if I really stuff the tire.
2006 Rubicon LJ, 4.0 liter, 4 speed automatic, 5.5" Rubicon Express, 37" x 12.5" Krawlers on Champion Beadlocks, Dynatrac Pro-Rock 60 axles/5.13 ratio w/ high steering kit, Dyna-Loc front hubs, J.E. Reel 1350 cv drivelines, Atlas 4 speed/5.38:1, Walker Evans Shocks, PSC Hydraulic Assist steering, Nth Degree Oil Pan and Transmission Skid, Premier Power Welder, Kilby On Board Air, Warn 9500si, Dual Optimas, Hansen Front Bumber, All J Products Rear Bumper & Boulder Bars, PIAA Driving Lights, Rock Lights, Ham Radio, CB, Garmin 76cs GPS,Wet-Okeole seat covers
CrawlinLJ is offline   Reply With Quote Quick reply to this message
Unread 12-01-2007, 04:48 AM   #6
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2
I'm interested to see the tires at full stuff. you may need to bumpstop a bit.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2007, 04:57 AM   #7
yellj
Do you still have the D30 up front. What are you doing for a spare?
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
www.midatlanticjeepers.com
yellj is offline   Reply With Quote Quick reply to this message
Unread 12-01-2007, 08:26 AM   #8
Nikos
4"lift and 1"bl are fine for 37s. flex the rear and take pics to check the rear steer with the 4link short arm setup.
2000 tj 2.5l 4.56 dana 30 aussie locker /super35 ARB, 35s maxxis crawlers, RE3.5sf, RE monotubes, 1"BL, currie anti-rock, currie steering, or-fab cage,ARB bull bar, warn m8000
Nikos is offline   Reply With Quote Quick reply to this message
Unread 12-01-2007, 09:04 AM   #9
jcssurf
Looks perfect. I would never go higher for 37's.
Why the 17's, if I may ask? Aren't those wheels and tires ridiculously heavy?
2004 TJ-L with 3-4" of lift, 35's, and no money
The Unlimiteds shall inherit the earth.
jcssurf is offline   Reply With Quote Quick reply to this message
Unread 12-01-2007, 09:17 AM   #10
jeepteejay
What is this Procomp triangulated 4 link in the rear? I didn't know they made one.
jeepteejay is offline   Reply With Quote Quick reply to this message
Unread 12-01-2007, 11:52 AM   #11
silvergreentj
They released the 4 link rear not too long ago...as for the 17s...if he plans on running any types of 37s beside super swampers, he wants the 17inch rim.
98TJ-33 Mtzs
Unread 12-01-2007, 01:20 PM   #12
Wup This
I went with 17's for a few reasons. It's a LOT more stable when aired down and it looks nicer IMHO. Also, 17's for the TJ's are a PITA to find. I actually wanted a 3.5 BS'd rim but could only find them in beadlocks which I didn't want yet. This also means the I won't run into many 17's on other TJ's, and I like to be different.
The 4 link came out a couple months ago. You have to tweek the tailpipe to clear this set up and the bushings they sent are a little big (I'm fixing that), so the bolt is a touch small and a slight clunk is audible if used this way. Other wise the kit is really nice. It actually trussed the rearend which is part of the design.
I bought the tires used so for a spare I'll buy a new TSL. I'm just waiting to see if I really like them as I wanted the Mud Grapplers instead. The tire is a 37 but it does measure smaller than other 37's as most SSR's usually do.
I haven't had a chance to disco and fully flex it out. I imagine I may need to adjust the stops then but connected they are adjusted to prohibit any rubbing when flexed.
D30 is still up front and will stay until broken. I am upgrading the gears and axles eventually. I also plan on trussing the front axle as well.
Unread 12-01-2007, 01:21 PM   #13
Wup This
Oh yeah........It's raining and snowing here. I'm thinking I may have to get muddy and take some new pictures. I'll make sure I get a pic of the rear setup before that though.
Unread 12-01-2007, 01:45 PM   #14
ktmracer419
1997 XJ Cherokee
how slow are the 3:73's with the heavy 37" swampers?
im sure your transmission will be loving it
ktmracer419 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2007, 02:00 PM   #15
Wup This
Again, not as bad as I thought. I actually don't mind it. I'm still regearing but it's honestly not bad. My speedo is about 8 mph off and the engine and trans aren't really struggling.
