4 driveshaft bolts holding up engine swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4 driveshaft bolts holding up engine swap
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 11-26-2010, 07:03 PM   #1
jerseyjeep22
We finally got everything from the drivetrain disconnected, the only thing holding us back are these 4 driveshaft bolts on the axle side. We have been PB blasting them for days, but can turn them. We are worried about snapping/stripping them, so we haven't used a crazy amount of force yet.
Can we use heat on these that close to the joint? Are these prone to snapping? We are hoping to get these off in the morning and the motor swapped over, so we only have to rent the hoist for a day. Any help is appreciated
jerseyjeep22 is offline   Reply With Quote
Unread 11-26-2010, 07:08 PM   #2
rivalarrival
Stormaggedon
rivalarrival's Avatar
Why not heat them up and just plan on replacing the spider? (If that's a stupid question, I apologize...)
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine
We work together every damn day. --Jon Stewart
Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it.
Low Output 4 Cylinder Jeep Club member #188
rivalarrival is offline   Reply With Quote
Unread 11-26-2010, 07:12 PM   #3
n8tmi
Screw the $12.00 joint and the $5.00 pinion seal and apply heat. Then clean the threads with a tap and call a day.
n8tmi is offline   Reply With Quote
Unread 11-26-2010, 09:25 PM   #4
ratmonkey
R.I.P.
ratmonkey's Avatar
heat them up, they are loctited in there. heat will break the loctite bond.
ratmonkey is offline   Reply With Quote
Unread 11-26-2010, 09:55 PM   #5
jerseyjeep22
ahh locktite makes sense, like ya said screw the $20 in parts we gotta get this swap going; heat it is
Unread 11-26-2010, 10:01 PM   #6
87warrior
Apply heat away from the pinion seal to melt the lock tite. If they do snap (mine have in the past) just use a screw extractor and remove. They are only torqued to 14lbs.
03 Rubicon(Rubicon build)
92 Comanche (92/99 Comanche Project)
86 Comanche (Heavy Four)
87warrior is offline   Reply With Quote
Unread 11-26-2010, 10:10 PM   #7
EricsGreen98Tj
Screw extractor=Easy-outs LOL
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline   Reply With Quote
Unread 11-26-2010, 10:11 PM   #8
Yuri
I'm pretty sure Napa sells a new strap kit w/bolts. Probably available at the other parts stores too. So if you snap one, new ones are available.
2001 TJ; 1999 XJ
Yuri is offline   Reply With Quote
Unread 11-26-2010, 10:52 PM   #9
jerseyjeep22
Yeah I have never had much luck with the extractors, but the only time they are ever used are in worst case scenarios haha. But yeah if they are only 14 lbs, either way they are comin out
Unread 11-26-2010, 10:54 PM   #10
jerseyjeep22
thats definitly good to know, always good to have a backup
The results will be in that frame swap thread once i dig that out and throw in some new pictures, thanks guys
Unread 11-27-2010, 02:19 AM   #11
conrasm
I've see the strap kits at advance and autozone in the "help" section.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
Heritage Region Jeep Alliance
conrasm is offline   Reply With Quote
