4 cylinder sputtering randomly - JeepForum.com
post #1 of 1 Old 08-25-2010, 01:49 PM Thread Starter
Utfan010
okay so i have a 4 cylinder 1997 SE, every once in a while when just started up or idling it will start to sputter down and come close to dying.....its done this twice on the road once while doing 60 and i had to pull off the road and it was fine.....and the other time today in 3rd gear it did it. i put it in neutral and got in the turn lane and was fine. but when it happens i can press the accelerator and something will start clicking and cluncking underneath me sounds to be coming from transmission, and then once i rev it once or twice it will be fine. ive done a little research, and came to a bad fuel pump, and a bad clutch sensor? any suggestions on what i should look for or listen to to lead me to the problem?
when in doubt, press the skinny pedal!
Utfan010 is offline
4 cyl , accelerate , clutch , idle , sputtering
Removing center console lock cylinder from latch cylinder Dstompe TJ Wrangler Technical Forum 11 06-27-2009 07:01 PM
How do you know whitch one is bad, Master Cylinder or Slave Cylinder? Morgan_TJ TJ Wrangler Technical Forum 19 08-06-2008 09:00 AM
Cylinder 2 misfire dead cylinder plenty of fuel Mel16m TJ Wrangler Technical Forum 10 11-27-2007 10:52 AM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
Help: A/C goes on and off randomly. Jiraiya TJ Wrangler Technical Forum 2 06-22-2005 04:13 PM
