4 cylinder to 6 cylinder - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4 cylinder to 6 cylinder
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiPoison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 07-06-2010, 12:41 PM   #1
2000TJMan
To go from I4 to an I6 how hard would it be, and what would have to be done, would it be worth the hassle.
2000TJMan is offline   Reply With Quote
Unread 07-06-2010, 12:42 PM   #2
Pillswoj
Just as easy to go V8
Friends don't let Friends run Bosch
Pillswoj is offline   Reply With Quote
Unread 07-06-2010, 12:48 PM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
It's usually better to just sell the TJ with the I4 and buy one with the I6. In addition to the engine, you'd need a different transmission, transfer case (or change its input shaft), the driveshaft lengths would need to be changed, a new engine wiring harness is needed, and you'd need a new engine computer. Not to mention the engine mounts would need to be cut off and new mounts welded into place.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Unread 07-06-2010, 12:52 PM   #4
2000TJMan
I figured it would be easier to buy one with an I6 just checking though. Thanks.
Unread 07-06-2010, 09:24 PM   #5
duglas25
I did it, as did many others on here.. It is as easy as going to a V8, but much cheaper..
I bought a wrecked TJ with I6 and swapped all the parts.. Other than welding new motor mounts on, it was all plug and play..
After selling the old parts and selling the rest of the wrecked TJ I broke even or actually made a few $$...
I could not be happier.. 4.10 gears from 4cyl, I6 power and torque.. Even with 35" tires it ran and has more than enough power..
2007 Rubicon Unlimited
SRT8 6.1L Swap Auto
RE 4.5" Long Arm
37" Cooper STT MT 17" Rims
Currie G2 D60 Rear, ARB 5.13
Mopar bumpers rear DVD, LockPick, MyGig, Sirius,
Full Soft Doors
TMD Hood
2005 Inifinti G35 4 Door 6MT
Stillen Stage 3 Supercharger
duglas25 is offline   Reply With Quote
Unread 07-07-2010, 11:49 AM   #6
JeepN95YJ
X2!
I've swapped V8s and the 4.0. There are way more issues to deal with swapping in a V8. Folks that say it is "just as easy" have never performed the swap. I'd rate the 4.0 swap as EASY and CHEAP. I just finished my swap of a 2002 4.0 into my 2001 TJ. I even reused the old mounts I cut from the frame.
JeepN95YJ is offline   Reply With Quote
Unread 07-07-2010, 11:54 AM   #7
gtstricky
Some light reading for you:
http://www.jeepforum.com/forum/f9/2-...derway-576008/
2.5L to 4.0L Engine and Transmission Conversion - Jeepaholics Anonymous
[COLOR="White"]Must reads for new TJ Owners:[/COLOR]
[url=http://www.jeepforum.com/forum/f9/tj-tech-boot-camp-must-read-new-tj-owners-forum-members-722109/] [COLOR="Yellow"]TJ Boot Camp Threads[/COLOR][/url]
[url=http://www.jeepforum.com/forum/f27/winch-basics-1004426/] [COLOR="Yellow"]Winch Basics[/COLOR][/url]
[url=http://www.jeepforum.com/forum/f9/lift-tire-questions-new-jeep-owner-1004989/] [COLOR="Yellow"]Lift Basics[/COLOR][/url]
gtstricky is offline   Reply With Quote
Unread 07-20-2010, 07:32 AM   #8
JeepN95YJ
Links to my swap:
http://4bangerjp.com/forums/index.php/topic,8673.0.html
http://forum.tkotrailriders.com/viewtopic.php?t=1977
Unread 07-24-2010, 11:44 AM   #9
2000TJMan
Thanks that last post was very helpful.
Unread 11-01-2011, 08:46 AM   #10
98Tjboy
Go to a v8 for some real power!
98Tjboy is offline   Reply With Quote
Unread 02-09-2012, 02:47 PM   #11
nic012cinko
yeah im looking to do this also, but i dont want to deal with the hassles of a V8. I just want to do the 4.0. Let me know if you find anything out! i would be happy to help you also if i find anything worth while.
nic012cinko is offline   Reply With Quote
Unread 02-09-2012, 03:45 PM   #12
clintrivera
clintrivera's Avatar
I'm curious what hassles a V8 swap has over a I6 swap. If you are mechanically inclined enough to do a I6 swap, a V8 swap is not much harder if harder at all.
clintrivera is offline   Reply With Quote
Unread 02-09-2012, 04:05 PM   #13
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Finding parts for the V8 swap is more difficult. For example, radiator hoses.
The wiring with the V8 swap is more difficult. No plug and play, you'll be splicing.
The exhaust for the V8 will be custom.
Transmission behind the V8 will often require a custom crossmember.
V8 will sometimes need gauges other than stock TJ gauges.
Wheelin98TJ is online now   Reply With Quote
Unread 02-09-2012, 04:23 PM   #14
clintrivera
As far as my LS swap went the stock lower hose that came with the engine worked fine cut down a little, the upper was a $10 universal hose. The wiring for the engine to run required two wires to be spliced in (ignition and fuel pump).
The exhaust was easy with a few bends, and if you don't get the whole donor for the I6, you will have to do some fabbing on the exhaust as well. My crossmember needed one hole drilled to work. Stock guages work great and I even have a tach with the Novak converter (stock senders in the block).
Not to mention the engine is lighter, has more power, gets better fuel economy, more potential to mod, sounds better, etc, etc...
Not a cheap swap though. On a budget I would have to go with the 5.2/5.9 magnum.
Unread 02-09-2012, 04:25 PM   #15
JBTJ
Why? yours won't do the speed limit?
JBTJ is online now   Reply With Quote
4 cyl , 6 cyl , swap , engine swap , difficulty , suggestions , help , TJ , advice
