4 cyl vs 6 cyl... better gas mileage? - JeepForum.com
post #1 of 37 Old 06-11-2008, 07:50 PM Thread Starter
PSYCH0
PSYCH0's Avatar
2016 JK Wrangler
What gets better gas mileage the 4 cyl or 6 cyl 5 speed?
I assume the 4 cyl but is the trade off in power from the 6 cyl worth the 1-2 mpg savings?
2009 Jeep Wrangler JK, 2-Door, Soft Top, Automatic, Black Procomp Aluminum Wheels with 315x75R16 Goodyear Wrangler Duratracs, 2" Black Diamond Lift, JKS Adjustable Track Bars, Smittybilt Rock Rails
PSYCH0 is offline
post #2 of 37 Old 06-11-2008, 08:02 PM
xxxflhrci
xxxflhrci's Avatar
If you plan on keeping it stock and want the extra 2 mpg, get a four banger. With a lift and larger tires, the mileage advantage of the 4 banger disappears.
xxxflhrci is offline
post #3 of 37 Old 06-11-2008, 08:12 PM
BENG
It's usually 2-4mpg. Difference is if I run my 4 cyl Jeeps hard on the throttle it doesn't matter. I can't seem to keep my foot out of the throttle on my six, and that becomes a problem!
So I say, yup get the 4 banger.
BENG is offline
post #4 of 37 Old 06-11-2008, 08:12 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i have a 4cyl my buddy has a 6cyl, both w/33s and 4:10s, we get the same MPG
RnEmOvr is offline
post #5 of 37 Old 06-11-2008, 08:26 PM
-Rudy-
What he said.
04 WJ Limited 4.7/QD: 245/70R17 Firestone A/T + Trimming
-Rudy- is offline
post #6 of 37 Old 06-11-2008, 10:51 PM
lupinsea
lupinsea's Avatar
One thing, though, is that on the trail there seemed to be a significant milage difference. A friend and I calculated TRAIL milage and came up with these figures:
Offroad:
6 cyl = 4.2 mpg
4 cyl = 7.2 mpg
On road he got better milage but not by much. Personally, our Jeeps get such crappy milage anyways that the 1-2 mpg saved isn't worth the lower power rating.
And I'd agress with xxxflhrci. If it's bone stock on those small stock 28's and will never be modded the 4 cyl is fine. Otherwise . . .
- Jay
lupinsea is offline
post #7 of 37 Old 06-12-2008, 03:24 AM
lloydsmale
2015 JK Wrangler
like he said at putting speeds in the woods the 4 is going to give you substantialy better milage but at highway speeds its about a wash.
Offroad:
6 cyl = 4.2 mpg
4 cyl = 7.2 mpg
lloydsmale is offline
post #8 of 37 Old 06-12-2008, 05:09 AM Thread Starter
PSYCH0
PSYCH0's Avatar
2016 JK Wrangler
Looking for it to be a daily driver to and from work in PA... about 50 miles round trip up and down hills all the way to and from...
PSYCH0 is offline
post #9 of 37 Old 06-12-2008, 05:54 AM
MudBox
get the six if your going to do any kind of oversized tires and then drive up and down hills
2003 Wrangler X
Originally Posted by vfrpilot View Post
and I keep a portable jump system in my rear during winter just in case!
MudBox is offline
post #10 of 37 Old 06-12-2008, 05:56 AM
BarneyJEEP
wheel the wrangler, get a compass or patriot or liberty for DD commuting....
BarneyJEEP is offline
post #11 of 37 Old 06-12-2008, 06:17 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
just get a 6-cyl w/ D44 rear so when its not enough power all you have to do is buy a stroker kit. if you get the 4-cyl, you'll have to do a more expensive motor swap and possible axle swaps.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 37 Old 06-12-2008, 08:20 AM
jgorm
jgorm's Avatar
+1. Even the4.0L is slow. Jeeps are heavy and have the wind resistance of a sheet of plywood. Up a very slight grade into a headwind i was floored in 4th to keep up with traffic.
jgorm is offline
post #13 of 37 Old 06-12-2008, 09:11 AM
carpekd
I don't know why but I laughed out loud
carpekd is offline
post #14 of 37 Old 06-12-2008, 09:47 AM
kloppk
A data point for you...
I have a 1997 TJ 4 cyl 5 spd on 33's w/4.10's
and a 1997 TJ 6 cyl 5 spd on 32's w/3.07's
Both consistantly get 20 mpg. Driven as DD's 40-65 on flat roads.
Hands down the 6 cyl is the better choice for power and acceleration.
kloppk is offline
post #15 of 37 Old 06-12-2008, 10:06 AM
BucketOKarma
Go with the 6, trust me, I have the 4-banger..... If you have to be doing anything with hills, and if your ever running late you will not want to be flooring it and barely moving. I wish I got the 6, I was stupid and thought "4cyl=better gas" but my (ex) wife's 6cyl gets the same mpg on flat ground, and better mpg on hills, and when going up hill she can keep her speed while I start to lag behind.
2000 2.5L 5spd 4.88, HP D30 w/OX, D35 open, 3" "FrAnKeNLiFt" with some stuff... LOOKING FOR Willys Edition TJ rear seat! to match the fronts.
BucketOKarma is offline
Vibration, Bad Mileage, Very Bad Mileage Harley_Jeep_Man TJ Wrangler Technical Forum 10 09-04-2010 06:55 PM
Mileage for the 4.2L JpBill YJ Wrangler Technical Forum 9 05-29-2008 07:15 PM
help with gas mileage baller88 TJ Wrangler Technical Forum 6 03-02-2005 08:05 PM
Gas mileage tj01wrangler TJ Wrangler Technical Forum 21 02-27-2005 03:32 AM
Gas mileage on a 87 2.5 YJ... All 4 Go YJ Wrangler Technical Forum 7 01-27-2005 06:01 PM
