4 banger yj into tj? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4 banger yj into tj?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-08-2013, 10:45 AM   #1
blackwidow98
My buddy has a 97 tj with a 4 cylinder and he's bolwn his engine... He has a parts yj sitting around with a good 4cylinder also. Are the engines the same and interchangable? And can he take his intake off the tj and put on the yj motor?
blackwidow98 is offline   Reply With Quote Quick reply to this message
Unread 08-08-2013, 11:02 AM   #2
Tonellin
What year YJ? My '89 was carb'd..I can't imagine going from a EFI to a carb'd set up would be easy
06 LJ Rubicon
http://www.jeepforum.com/forum/f22/lj-rubicon-build-1481013/
Tonellin is offline   Reply With Quote Quick reply to this message
Unread 08-08-2013, 11:49 AM   #3
blackwidow98
Its a 96 yj
Unread 08-08-2013, 11:59 AM   #4
prjohnson
Originally Posted by blackwidow98 View Post
Its a 96 yj
There's no 96 Wrangler. Likely a 95
prjohnson is offline   Reply With Quote Quick reply to this message
Unread 08-08-2013, 12:11 PM   #5
Jeepsr4me
No your 89 4 banger was not carbed from factory........ And I assumed the OP just wanted to swap the long block parts not the tbi too.
Blocks are the same. Oil pan will have to be swapped and maybe the pump pickup. I have examined nearly every year model 2.5 and there just in no differences in the long blocks for installing purposes. Some gaskets and bearings are different between years.
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 08-08-2013, 01:02 PM   #6
Tonellin
Sorry, I didn't point out that I had the 4.2 in my '89. I figured that since my 6cyl was carbed so was the 4
06 LJ Rubicon
