4.88 vs.4.56 gears - JeepForum.com
post #1 of 52 Old 08-17-2012, 12:43 AM Thread Starter
humbled
4.88 vs.4.56 gears
I am about to do it. 4.0 with 3 speed auto with overdrive. 33 in tires. I favor the 4.88. What do you guys think ?
humbled is offline
post #2 of 52 Old 08-17-2012, 12:48 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
What year is your Jeep?
Filling in your profile helps...
Knuckelhead is offline
post #3 of 52 Old 08-17-2012, 12:56 AM Thread Starter
humbled
2006. Yes, I should fill out my profile.
humbled is offline
post #4 of 52 Old 08-17-2012, 04:02 AM
AlexGeorgakis
i'd say stick to 4.56 if you're going to be using 33s. I was happy with that ratio.
AlexGeorgakis is offline
post #5 of 52 Old 08-17-2012, 05:52 AM
jefro_97tj
He should have the 42rle 4speed where your 01 had the 32rh 3speed. I'd say 4.88
jefro_97tj is offline
post #6 of 52 Old 08-17-2012, 08:32 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
4.88 without a doubt.
RPM will be about 2,500 at 70 MPH which is perfect.
Wheelin98TJ is offline
post #7 of 52 Old 08-17-2012, 09:05 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep your 2006 has a 4-speed automatic, the 42RLE, it is not a 3-speed that was last used in 2002. Based on that, you should be running 4.88 for 33" tires. Don't even consider 4.56.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #8 of 52 Old 08-17-2012, 10:23 AM
Budke
While were on this topic and instead of making a new thread about it.
From what I've researched for my 4.0 5speed 4.56 gears would be a good choice correct? I'm running 33s and will be upgrading to 35's when the tread wears out on these which will be by the end of the year more then likely.
Sent using the force
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #9 of 52 Old 08-17-2012, 11:09 AM
BillGOTD
I had 4.56 gears with 33s and was happy with the combo. When I switched to 35s it was still good, but I recently switched axles and changed to 4.88s and am glad I did. You could certainly get by with 4.56, but I prefer 4.88.
BillGOTD is offline
post #10 of 52 Old 08-17-2012, 11:34 AM
Jerry Bransford
Administrator
4.56 is ideal for 33" tires but since you will be going with 35", I would regear to 4.88.
Getting
post #11 of 52 Old 08-17-2012, 02:41 PM
Redrum
Jerry,
If I remember correctly I seem to recall you once recommended 4.10 for jeeps with the 32RH running 33's?
Redrum is offline
post #12 of 52 Old 08-17-2012, 03:15 PM
gebirgziege
I had a quick question regarding gearing too.
Are 4.88s ideal for 35s on a 2006 LJ auto and laden with steel? Should i look into that?
And will I be continuing to turn of the OD button with 4.88s?
Or should I look into 5.13s? I occasionally pull a trailer, wheel on hefty rocks and stuff.
Currently it's got 4.10s w 33s and it seems if I go to 35s and 4.88s I will be continuing to push the OD button off. Is that so?
5.13s and 35s, or 4.88s and 35s?
What's the opinion/knowledge on this?
I would like to learn a little more.
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
post #13 of 52 Old 08-17-2012, 04:05 PM
Jerry Bransford
Administrator
Your 4-speed auto's overdrive ratio is so steep that for 35" tires, I'd definitely go 5.13 or probably even 5.38 for 35" tires. After my previous TJ was stolen, I bought a used Rubicon with 35" tires and 4.88 gearing and it's a terribly frustrating combination, the engine lugs so often on the highway that I am nearly constantly jabbing the Overdrive switch to get the RPMs up enough to stop it from lugging.
When I had my previous TJ with 35" tires and its 5-speed, 4.88 was ideal. But the 4-speed automatic changes all that, it needs a substantially lower ratio like 5.13 or 5.38 to bring the rpms to where they need to be.
Getting
post #14 of 52 Old 08-17-2012, 11:52 PM Thread Starter
humbled
4.56 vs. 4.88 gears
Thanks everyone for your replies. Sounds like 4.88 with my 42rle auto trans is the setup I need.
humbled is offline
post #15 of 52 Old 08-18-2012, 12:35 AM
gebirgziege
Thanks Jerry.
I'm going to look into 5.13s a little more. I've seen them cheaper than 4.88s too, so that's a little bit of a plus.
I have also heard that 4.88s are stronger than 5.13s- is this true?
Has anyone ever driven a similar setup?
4 speed w 35s and 5.13s vs the same w/ 4.88s?
Could you tell a difference?
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
Jk Rubicon 4:10 gears vs. 1974 Chevy 4:10 gears (pics) Xtremjeepn JK Wrangler Technical Forum 15 12-03-2009 09:09 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 10:54 AM
