4.88 gears with 33s on a Rubi - JeepForum.com
post #1 of 21 Old 09-22-2006, 09:10 PM Thread Starter
toastervet
Has anyone put 4.88 gears with 33s ? I have a Rubi Unlimited with auto. It seems like it would help balance out the overdrive and give more power.
toastervet is offline
post #2 of 21 Old 09-22-2006, 09:17 PM
McLovin
yes it would give it more power
McLovin is offline
post #3 of 21 Old 09-22-2006, 09:29 PM
BillR
BillR's Avatar
Umm...wrong! OMG, I can't believe you wrote that!
It lets the engine operate more in it's powerband, but gears (OBVIOUSLY!) do NOT increase the engine's power. The engine's more efficient with the proper gearing.
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #4 of 21 Old 09-22-2006, 09:31 PM
BillR
BillR's Avatar
It's a nice combo if you have an overdrive tranny.
BillR is offline
post #5 of 21 Old 09-22-2006, 10:04 PM
lostatsea346
with those gears you will definately have some serious torque....and i dont mean likee your engines hp will change, but you will feel more power at lower rpms, bcause your gearing is changed....so dont quote me and tell me im wrong...
'06 Unlimited 4'' OME plus 1" RE spacers...
Once you go black, you dont go back
lostatsea346 is offline
post #6 of 21 Old 09-22-2006, 10:22 PM Thread Starter
toastervet
What about the transfer case?
I think that would change low range to an equivalent 4.5 to 1 . Would that be a problem?
post #7 of 21 Old 09-22-2006, 10:25 PM
Envygreen
I'm running 4.88 on 33, and im in temecula if you want a test drive, it might not be the best for daily use? But i only use mine off road
Envygreen is offline
post #8 of 21 Old 09-22-2006, 10:28 PM
RLD831
RLD831's Avatar
It wouldn't change your low range, it would only change your ending ratio. You need to multiply the three ratios to get your end ratio, but your Rubicon transfer case will still be 4:1. You multiply the ratio of your transmission gear by the ratio of your transfer case by the ratio of your axle. So yours would be 4.88 x 4 x (transmission ratio).
RLD831 is offline
post #9 of 21 Old 09-23-2006, 01:42 AM
lostatsea346
you could do a handstand and see if that helps
post #10 of 21 Old 09-23-2006, 02:39 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
that was a really condescending response.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #11 of 21 Old 09-23-2006, 05:46 AM
BillR
BillR's Avatar
Yes, it was... I was making a point due to...
what part of 4:1 transfercase don't you understand?
And...
OMG I can't believe you just wrote that.
And now, back to your regularly scheduled posts...
BillR is offline
post #12 of 21 Old 09-23-2006, 08:38 AM
steve3911
For those running 4.88s, with the auto, what kind of RPM do you have in OD? I was going to go 4.56, but now I'm leaning toward 4.88 with my 33s for now. (35" tires in a couple years, don't want to regear again).
~Steve
04 Unlimited
4.5" RE long arm, 1.25 JKS body lift, 35" Coopers STTs (And some boggers soon), skid row oil and steering box skids, warn 9000i winch, skidrow nightcrawler front bumper, hanson rear bumper w/ A frame tire carrier, shrockworks rocker protection, SYE, CV Driveshaft, ARB diff covers, Currie tie rod system, KC lights, CB, and tons of other stuff.
steve3911 is offline
post #13 of 21 Old 09-23-2006, 11:35 AM
crgrissom
Master of Reality
crgrissom's Avatar
Actually, power depends on leverage and the deeper gears have more leverage with the same engine/tranny, so yes, there will be more power at the wheels, which is all you feel anyway.
Chuck (35's and 4.88's on the way...)
Chuck Grissom
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline
post #14 of 21 Old 09-23-2006, 01:06 PM
McLovin
Umm acutally I am not wrong. I consider power to be a combination of HP and torque.....Gears multiply the torque......Nice try though
McLovin is offline
post #15 of 21 Old 09-23-2006, 05:31 PM
BillR
BillR's Avatar
I "consider" power to be HP at the engine. Gears don't change that, last time I checked.
Thanks though.
BillR is offline
3.54 gears on a Rubi air locker? RockRodHooligan TJ Wrangler Technical Forum 7 01-12-2010 10:57 AM
Just bought a TJ Rubi. Which gears should I run? omgwtfbbqcopter TJ Wrangler Technical Forum 8 12-19-2009 01:29 PM
D44 Rubi Gears gmd JK Wrangler Technical Forum 10 02-25-2009 11:14 AM
06 rubi gears daver032 TJ Wrangler Technical Forum 2 06-26-2007 03:42 PM
05 Rubi gears on an 06 non-Rubi? surfcaster TJ Wrangler Technical Forum 7 02-13-2007 05:29 PM
