4:88 or 5:13 for RUBICON WITH AUTO & 35'S - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4:88 or 5:13 for RUBICON WITH AUTO & 35'S
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 09-13-2009, 08:20 PM   #1
YOGI1
I just recieved my new 12:50x35x15 BFG KM2's and MT's 15x8 sidebiter's.I have a 06 rubicon with a auto trans can anyone chime in that are running 4:88's and 5:13's and help me decide on a ratio. this is not my daily driver but i still want to be able to go where I want including the interstate. I don't mind driving a little slower I was leaning towards the 5:13's to be alittle easier on the drive train I also will be installing rear cm shafts at the same time.
YOGI1 is offline   Reply With Quote
Unread 09-13-2009, 08:24 PM   #2
Imped
Balls
Imped's Avatar
You have a 42rle trans, in case you didn't know. 5.13 for sure. That will help overcome your tall OD.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 09-13-2009, 08:34 PM   #3
RJV
I have 4.88s and 33s. 4.88 was the tallest I could go with because of my front axle. the jeep drives good but wish the gear was a little taller. definetly go with 5.13s if your going to run 35s.
RJV is offline   Reply With Quote
Unread 09-13-2009, 08:35 PM   #4
Dmcastino
5.13 ten characters
Dmcastino is offline   Reply With Quote
Unread 09-13-2009, 08:43 PM   #5
Imped
Balls
Imped's Avatar
You're confusing the terms tall with low. Numerically higher gears are "lower" and "shorter", not taller. Taller gears assumes numerically lower gears, which are higher.
3.07 with 35's=very tall/high
5.13 with 35's=short/low
OlllllllO
Float Test Build
IndyORV
Unread 09-13-2009, 09:17 PM   #6
uvalax236
I have 5.13's with my 315/75/16 (35's) Nitto Terra Grapplers. Love the gearing!
06 Solar Yellow AT
Banks Headers, ARB Periscope, Clayton LA/TT,
Coast 1350 Shaft, JKS BL/BMML/Quicker Discos/Adj BumpStops,
RE 4.5 Springs/BrakeLines/HD TB, Currie Steering, VVME 3000k, 6000k HID Systems, IPF H4 Headlights,
315/75/16 Nitto Terra Grapplers on Moab's, 5.13's and TruSpeed
uvalax236 is offline   Reply With Quote
Unread 09-13-2009, 11:04 PM   #7
mudb8
want it rite or rite now?
mudb8's Avatar
at least 5.13's.... the only thing stopping you from what you need is the rubi locker carrier. that's as low as it gets....
I've had both 4.88's and 5.13's.. my next gear change for the 35/36" tires is 5.89's and bye bye rubi lockers, even tho I love em so much...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
See Me @ Jeep West, Portland, Or.
Is your jeep for sale?
mudb8 is offline   Reply With Quote
Unread 09-14-2009, 06:37 AM   #8
pielet97
Looks like I"m in the minority, but I have 35 MTRs w/ the 42RLE and 4.88s. I love the way it drives. Its peppy and cruises at 75mph at about 2300 rpm. I would think highway mileage would suck with 5.13s, but I don't know. I get between 15 and 18 depending on the conditions.
I require things to do.
pielet97 is offline   Reply With Quote
Unread 09-14-2009, 06:53 AM   #9
robncar
You get between 15 and 18MPG with 35's on an LJ!!?? What speedo gear are you running, or if a Rubi, how'd you convert the speedo signal?
The difference between 4.88 and 5.13 is about 5%. So, 1000 RPM becomes 1050, 2300 becomes 2415. It'll hardly kill your highway mileage.
If we had it to do over again, we would have replaced the stock D30 and be running lower than 4.88 with our 35's and 42RLE. This transmission loves low gears.
[CENTER][SIZE="5"][COLOR="DarkRed"][B]DON'T FEAR THE RE-GEAR!!![/B][/COLOR][/SIZE]
[CENTER][B][COLOR="DarkRed"][SIZE="3"]______[/SIZE]
[SIZE="3"]|_____|[/SIZE]
[SIZE="2"](O|||||||O)[/SIZE]
[SIZE="1"]|______|[/SIZE][/B][/COLOR]
[SIZE="5"][][/SIZE]===[SIZE="5"]o[/SIZE]==[SIZE="5"][][/SIZE][/CENTER]
[SIZE="4"][COLOR="DarkRed"][B]RED JEEP CLUB MEMBER #430[/B][/COLOR][/SIZE][/CENTER]
robncar is offline   Reply With Quote
Unread 09-14-2009, 08:43 AM   #10
bfewkwa
bfewkwa's Avatar
I've got 35's and 4.88s with the 42RLE. Just got my Rubi about 3 weeks ago.
After driving it for the first week, my initial impression was that I would want to go with 5.13s in the very near future. After driving with it for a few more weeks and learning the Rubi a little better, I think the 4.88s are good enough for now.
That said, if I were in your shoes and choosing one or the other, 5.13s would probably be my choice.
Here's a thread I had started about the same topic:
http://www.jeepforum.com/forum/f9/35...-gears-845621/
bfewkwa is online now   Reply With Quote
Unread 09-14-2009, 08:47 AM   #11
00jeepred
i know a kid with a rubicon who has 5.13's and 37's with a manual trans. and he goes through r&p gears like water. In the process of going to d-60's. at that low of a gear the pinion is so small that there is not alot of tooth contact.
00' jeep Rock Krawler 4" plus, Bilstine 5100's.
33" BFG KM2 on Craiger Soft 8's, A.A. SYE, Tom Wood Drive shaft,
I wave.
00jeepred is offline   Reply With Quote
Unread 09-14-2009, 08:53 AM   #12
Imped
Balls
Imped's Avatar
You are very right. OP, unless you'll really be beating the absolute crap out of this rig offroad, then don't worry about the tooth contact issue. Otherwise, you'll love the 5.13's.
OlllllllO
Float Test Build
IndyORV
Unread 09-14-2009, 09:13 AM   #13
RubiconRazorbac
RubiconRazorbac's Avatar
I can tell you right away, at least in this case, the relative weakness of the R&P is minimal compared to the inherent problems with the driver.
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
KOH EMC thread: http://www.jeepforum.com/forum/f22/p...build-1476559/
RubiconRazorbac is offline   Reply With Quote
Unread 09-14-2009, 01:07 PM   #14
pielet97
This was the first trip from Cali to Indiana, I just bought it. I compared the trip odometer to the fuel used and only got into the 14's twice, in the mountains. It is a Rubicon, and I don't think there is a conversion box. I did notice the the speed was indicating about 5mph faster than the GPS, at 75mph(speedo).
We agree the RPMs won't change with gearing, so you're saying the speed is slower and the mileage is less than shown? I'd agree to that. After doing some math, and assuming the 5mph at 70 is exact, my mpg would go to 14-17. About 6.6% less, or 1mpg.
With your statement, only a 5% change in rpm, you're assuming the fuel flow curve is linear, and we all know it is not. You don't burn twice the fuel at 2000 as you do at 1000, and 2K-4K. Just not true, it burns significantly more as the rpms increase.
Unread 09-14-2009, 01:45 PM   #15
RubiconRazorbac
That's what you'd think intuitively. However, the Jeep is like a brick-shaped parachute going down the road. You need the gearing to keep you in the power curve for maximum efficiency. You will get better gas mileage at 2500 rpm in the correct gear than you will "lugging" the engine at 2000 rpm in the wrong gear.
With 5.13s it'll take less effort for your engine to keep the Jeep moving even if the rpm's are higher. It's all about being able to overcome the resistance.
