4.56 gears..ebay dana spicers? - JeepForum.com
post #1 of 12 Old 08-05-2010, 10:01 AM Thread Starter
TJbarber
Hello there,i am on the market for 4:56 gears i have an 03 TJ with 35" rubber.can u guys have a look at the link posted and tell me if thats what i need. I have higher gearing so i will need different carriers i already know that.
DANA 30 DANA 35 GEAR PACKAGE JEEP YJ XJ TJ MASTER KITS: eBay Motors (item 390216594475 end time Aug-06-10 09:29:21 PDT)
My Mech wants around $800 for a set...all said and done i could get these for roughly $600 tax and shipping inc just wanna make sure everythings there.
TJbarber is offline
post #2 of 12 Old 08-05-2010, 10:39 AM
crusher242
Looks good from my house, but if you look around a little you can find the gears for around the same price on other sites and you could get 4.88's which would be much better IMHO.
Hold onto something... Quick!!!
crusher242 is offline
post #3 of 12 Old 08-05-2010, 10:46 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I'm not sure about the brand.
It says "Dana Spicer Motive".
You're probably getting Motive brand gears rather than Spicer brand.
Wheelin98TJ is offline
post #4 of 12 Old 08-05-2010, 10:48 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If you buy the gears on your own and give them to the installer to install, what happens if something goes wrong? Is the installer going to cover the gears in his warranty? I would never consider providing the gears to the installer because if something goes wrong, and it happens, the installer will likely blame the gears and the gear seller will definitely blame the installer. You are then stuck in the middle with them pointing fingers at each other.
I would simply ask the installer to discount the cost of his gears closer to what you can buy them for and let him provide everything. That way his warranty will cover everything and not just his labor.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #5 of 12 Old 08-05-2010, 01:14 PM Thread Starter
TJbarber
Jerry thats the best answer ive ever gotten on here..you are so right about that,for the $150 im gonna save its not worth the headache if something does go wrong with the gears,thanks for the insight!!
TJbarber is offline
post #6 of 12 Old 08-05-2010, 01:14 PM Thread Starter
TJbarber
totally off topic..how do you guys put a picture in your profile window?
TJbarber is offline
post #7 of 12 Old 08-05-2010, 01:27 PM
Jerry Bransford
Administrator
Click on "User CP" and look for the Avitar area that allows you to upload a suitably sized .jpg image.
Getting
post #8 of 12 Old 08-05-2010, 02:03 PM Thread Starter
TJbarber
Edit profile picture? do you see my pic..i dont,strange
TJbarber is offline
post #9 of 12 Old 08-05-2010, 02:08 PM
Jerry Bransford
Administrator
Go straight down directly under User CP once you click onto that page where you'll find the "Edit Avitar" link in the "Settings & Options" section.
Getting
post #10 of 12 Old 08-05-2010, 02:19 PM
Wheelin98TJ
JEEP FREAK
Avatars are limited to supporting members.
It used to be that anyone could have one, but that changed a few years back.
post #11 of 12 Old 08-05-2010, 06:35 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Tell me more about your rear axle?...
TJBARBER'S JEEP
Year & Model
Engine
4.0 liter
Front Axle
Dana 30-stock
Rear Axle
Dana 33-stock
Knuckelhead is offline
post #12 of 12 Old 08-06-2010, 05:14 AM
crusher242
Man those dana 33's are rare.
dana , spicer , gear , tj , wrangler , buy , buying , advice
Will spider gears from dana 30, fit in a dana 35? jeeper92 TJ Wrangler Technical Forum 5 07-31-2010 08:21 AM
dana 30 gears from a 94 Yj gears into a 2005 tj jewem TJ Wrangler Technical Forum 5 12-16-2009 03:21 PM
Dana 35 Gears Fit Into Dana 44 Diff. _JEEP_ YJ Wrangler Technical Forum 7 10-03-2008 10:02 AM
Dana 44 on Ebay for 999.. RVA_TJ06 TJ Wrangler Technical Forum 2 06-27-2008 10:45 PM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
