#1 | |
4.56 Gearing On 4spd Auto
I was wondering if anyone has this setup on a 32" tire. I am currently running 3.73. I would like to retrieve some performance back but I also don't want to be screaming down the freeway either.
Thanks
3rd time around with 2006 2.4L 6sp, warn bumpers front/rear, clean slate to work with-need ideas.... |
#2 | |
[URL=http://tednugent.com][COLOR=Red]www.tednugent.com[/COLOR][/URL] [SIZE=1] [COLOR=navy]2001 Sport 4.0L, 5 Speed, Patriot Blue 33 X 12.50 BFG A/T's with A/R Atlas 15 X 8 wheels 4.56's, RE 3.5" lift, Currie 1" BL, M.O.R.E. 1" MML Aussie D30 Locker, & other crap[/COLOR][/SIZE] |
#3 |
32s auto 4.56 is an over kill maybe 4.10 but you will be fine with stock gears
Rustys 5.5 lift, ,35s, stinger, soon to put on 4.88s, super35 w/arb and front arb air lockers |
#4 |
unless you imminently plan on going to a bigger tire you *will* be screaming down the highway. Although I dont have personal experience with the 4spd. I know it would not be a desireable combo with the older 3 spd torque flite- what I run.
[SIZE=2][COLOR=Navy]MK Motorsport & Fabrication [/COLOR][/SIZE] |
#5 |
i would say do it (4.56) i have 4.10's and 32's (street tires) and i find myself wishing i had more gear. also, my 5spd has a .79 5th gear--isn't the 4spd auto .69 od? i think 4.56's would be great--especially when you go to 33's or 35's--and you know you will eventualy.
Y2K 4L 5spd TJ Sport--4.5" RE SF all adj. arms--1" BL--1" MML--33"bias swampers(soon to be 36" swamper sx's on rockcity diy beadlocks)--D44 4.88's arb w/alloy usa shafts--HPD30 4.88's locrite w/warn alloy inners--warn small hub kit--longfield hd u-joints--currie steering--currie anti-rock--tera low--A-Z Fab cage--and a bunch of skids |
#6 |
I have a 5 speed and run 4:10/11 with 33" and 32" Yeah I have to sets long story.
A good rule is with an auto drop one set ratio down from the stick jeeps. Your equivalent is 4:10 When I have the 32" the 4:10/11 are great. Only on the steepest of grades do I need to down shift. With the 33" MTR I wish I had the 3:56" Now I do a lot of up hill driving. The cost in for gearing can be a hell of a lot. Unless you are always in 3rd and 4th is gone I would sit tight. For me I'll be putting 4:88 when I go to 35" in a few years.
01 Sahara, Nice paint job. Locked, 4" 33 MTR's, 4:1 Xfer, Warn Hubs, Winch, Bull Bar, Big lights, Nth degree flat tummy tucker. Lots more ready go climb a rock. Last edited by khunjeep; 10-24-2004 at 09:35 PM.. Reason: typos |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
