4.5" RE long arm installed- now shifting probs. Help? - JeepForum.com
post #1 of 12 Old 12-01-2009, 12:19 PM Thread Starter
VanBCguy
I recently had a 4.5" RE long arm lift installed. Of course, a CV and SYE were used with it. It's a custom tri-link in the rear. 5.13 gears in D44 axles. No tranny or t-case lift was done.
But here's the problem: Ever since the moment I picked it up, I have trouble finding exactly where my 1st gear and 3rd gear is. I feel like I'm in, but not nearly as deep as I used to be (the throw is shorter). And many times, if I'm in first (or so I think) when I go to pull away from a stop light, the shifter will pop out of what I thought was first. I can also be in 3rd gear and driving, let off the throttle and then lightly back on and *poof*, I've popped out of 3rd. Clutch in, swing the shifter down to neutral, back into 3rd, problem fixed.
But this was never the case before my suspension install. I had a longer throw into the top gears (1st, 3rd, 5th) and I NEVER popped out.
I hope I've described this well enough. If you need more details, please feel free to ask.
Help?
VanBCguy is offline
post #2 of 12 Old 12-01-2009, 01:38 PM Thread Starter
VanBCguy
bump for help?
VanBCguy is offline
post #3 of 12 Old 12-01-2009, 02:25 PM Thread Starter
VanBCguy
Really? No-one?
Help? Please?
VanBCguy is offline
post #4 of 12 Old 12-01-2009, 04:45 PM
Piratejonh
Piratejonh's Avatar
Pull the shift boot off and see if the shifter is hitting the edge of the hole. The transmission may be in just a little bit off with the new belly plate, causing the shifter to hit.
Jeep took another piece of my finger today...
Piratejonh is offline
post #5 of 12 Old 12-01-2009, 04:49 PM
Fropleyqk
Fropleyqk's Avatar
x2
You didnt have a BL done at the same time did you? Dont really see how that would effect 1st and 3rd though....
Make sure the tranny and skid are sitting correctly. When the shop did your SYE theres no telling what they might have removed. Check the tranny mount too.
Fropleyqk is offline
post #6 of 12 Old 12-01-2009, 04:52 PM
yarmish
i had the same feeling after i installed my RE long arm upgrade kit. it is that the new belly pan raises your transmission a few inches therefore 1st 3rd and 5th and are now a few inches more forward if you get what i am saying? Basically it will just take a lil getting used to.
hope this helped
In a ZUK now....
yarmish is offline
post #7 of 12 Old 12-01-2009, 07:53 PM Thread Starter
VanBCguy
hope this helped
Not to disregard the above comments because they're both pretty on the mark, but yours seems to have nailed it. Unfortunately, this isn't something I could just "get used to". My shifter pops itself out of gear when I throttle up at all and 1st is extremely hard to find. Maybe if the tranny has moved forward a bit, I could cut back the front of the hole?
Ideas?
VanBCguy is offline
post #8 of 12 Old 12-01-2009, 11:36 PM Thread Starter
VanBCguy
Bump to get "unlost" amongst the many threads?
VanBCguy is offline
post #9 of 12 Old 12-02-2009, 04:45 AM
yarmish
yours seems to be worse than mine,i had a few times where i thought it was in gear and would come out upon releasing the clutch but that was only for the first few drive's after the long arms. did you maybe have a t-case drop before this lift was installed making it a big change for you?
In a ZUK now....
yarmish is offline
post #10 of 12 Old 12-02-2009, 05:03 AM
ISurvivedNMU
Ideas?
As the others have said. Take your shift boot off and see where it is hitting. You can bend the sheet metal of the body to make it shift better, or you can bend the shifter.
2006 Jeep TJ Rubicon... Currie 4" Lift, ect...
2011 Grand Cherokee Overland
2015 JKU Hard Rock
ISurvivedNMU is offline
post #11 of 12 Old 12-02-2009, 10:18 AM Thread Starter
VanBCguy
Thanks guys. To answer the most frequent question so far, no I didn't have had a t-case drop.
Im going to remove the boot today and see what I can find. I'm not very up on tranny issues, but I'm assuming it's as easy as looking to see if the shifter shifts into the front gears (1st, 3rd, 5th) without bumping into the body and/or plastic console.
I'll post my results so that, if needed, I can beg for more help.
VanBCguy is offline
post #12 of 12 Old 12-02-2009, 06:10 PM Thread Starter
VanBCguy
Thanks to all that have made posts with solutions/ideas. I took the boot off today and found that the plastic attachment at the bottom of the shift lever was hitting the front of the centre console. Quite obviously, my build had changed the height of tranny and shifter and moved it forward a bit.
I took it to my tranny shop and they Dremel'd it so that it "fits" and shifts with clearance. Charge? $0.00
Yet another fine example of JF members saving me tons of headaches and money.
Thanks guys! You all rock.
VanBCguy is offline
RE 4.5" Tri-Link Long Arm - INSTALLED! SuperWade2 TJ Wrangler Technical Forum 46 11-30-2009 07:14 AM
Just installed 5.5" RE long arm kit countryboy4ya TJ Wrangler Technical Forum 6 11-12-2005 06:51 PM
still have probs with tcase shifting joe johnson TJ Wrangler Technical Forum 7 04-03-2005 10:01 PM
My Jeep with 5.5" RE Long arm kit installed Jbirdman97TJ TJ Wrangler Technical Forum 27 08-13-2004 07:53 AM
Fuel probs after 1" lift installed semper fi YJ Wrangler Technical Forum 3 03-25-2003 04:22 PM
