4.5" coils and short arms? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4.5" coils and short arms?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 11-28-2005, 07:36 AM   #1
BillR
Is 4.5" too tall to continue to run short arms? I have a set of JKS lowers that I'm fond of, but I'm hoping that I won't trash the ride with the longer coils. I see that several vendors including RE make a 4.5" kit w/SAs, so it can't be REAL bad...(can it?)
Any and all opinions are welcome.
'05 LJ Sport, 6-speed, SwayLoc, LoD bumpers...the build begins!
'11 JK Unlimited Sport S, stock for now...
BillR is offline   Reply With Quote
Unread 11-28-2005, 07:57 AM   #2
Muddeprived
Just a little rougher ride from the angle of the control arms..but it's do-able.
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote
Unread 11-28-2005, 08:03 AM   #3
fisher836
I'm at 6" with short arms. The rides not really bad at all. The flex isn't very good and every once in a while I'll hit a bump that throws me like a rodeo bull. I think 4.5 is definetly ok though. You're not pushing it too bad at all.
The problem I am personally running into now is, I installed a SYE and CV and I am still getting DL vibration because my upper control arms are stock in the rear so the yoke is pointing straight ahead and creating a bad angle. I am either going to make or purchase adjustable upper control arms. At 4.5 inches, I'm not sure if you'll run into that problem or not. Just an FYI. Good luck with it!
Definition of Rubicon:
A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
fisher836 is offline   Reply With Quote
Unread 11-28-2005, 08:09 AM   #4
BillR
I should be OK there, as I have adjustable uppers AND lowers in the rear.
Thanks!
Unread 11-28-2005, 08:10 AM   #5
scrappy
i run them and think the ride is just as good as when i had a 2.5 rancho kit on it, actually better. i wouldnt worry about it.
99 TJ Sport 4.0 5sp, 30/44 aussie/truetrac and 4.88's, 4.5 RE, 1"BL/MML, 35" Toyo M/T's, Ramsey REP8000, JKS discos, Warn Flares 6", Tera rear discs, Jeeperman sliders and rear bumper/tire carrier, Nth oil skid, Currie HD steering, 33 engineering TT skid, JB conversions 231HD transfer case w/SYE/CV, Kilby steering box skid/gas tank skid, incab winch controller, Edge Trail Jammer, Baja RS seats, Viair OBA,
My Jeep
scrappy is offline   Reply With Quote
Unread 11-28-2005, 08:13 AM   #6
fisher836
Thanks!
I think you're golden then!
Unread 11-28-2005, 11:33 PM   #7
cjdirtbiker
I run a currie lift. The rear springs were too soft for loaded-for-trail camping so I swapped 'em for RE 4.5". Perfect. Fronts are still Currie 4".
With bar pin eliminators and shock shifters the Ranchos were bottoming out, so the extra clearance works great with them along with longer bumpstops. I even went down and talked to John Currie personally, he said 'we just don't have a problem like that.' But then they tow their rigs out on a trailer and wheel them empty, so yeah, they've never run into that problem!! And that was with their "HD" for hardtop springs. They were progressive wound and the lighter rate coils were always bottomed out on themselves.
I may still opt for the RE long arm conversion. Just run it with my Currie arms and rancho shocks! It's about a $1400 upgrade. I'm not sure what benefit I would get with them. I think I'd rather spend the money on a HP30 setup with ARB for the front axle.
[COLOR=Wheat][SIZE=2][FONT=Tahoma]Chris Brown
'02 "X" 4.0 AT - Lifted and locked on 35's, D44/4.10, ARB, GY MT/r's, Currie, JKS, MORE, AA/TW, Rancho, WARN 8274, Hansen, All-J custom bumpers, Poison Spyder, CO2, Cobra, Hella, and on and on: J.E.E.P.
[URL=http://pg.photos.yahoo.com/ph/cjdirtbiker@sbcglobal.net/album?.dir=75b8&.src=ph]Photo Album[/URL]
STOLEN 3/05: 99 TJ, built for trailrunning
[/FONT][/SIZE][/COLOR]
cjdirtbiker is offline   Reply With Quote
Unread 11-28-2005, 11:43 PM   #8
4JEEPN
I run the 4.5 re with 2" spacer in the front, none the rear.. does just fine, flex is fine too.
00 TJ: Built.
4JEEPN is offline   Reply With Quote
