4.11 Rearend - JeepForum.com
post #1 of 3 Old 08-04-2010, 07:52 AM Thread Starter
bmw328in
4.11 Rearend
I just bought a 1997 tj 2.5 that a guy stiffed my on but owe well. The rearend is bad and has electrial promblems. Where is the best place to get a rearend rebuild kit or where could i find a good used one. Also I need a under dash wiring harness will a 4.0 harness work. thanks for any help
bmw328in is offline
post #2 of 3 Old 08-04-2010, 09:29 AM
RikatyJeep
My first question is how did you not realize the rear end was bad?
Whats wrong with the rear end that makes you think you need a new one?
A junkyard would be your best bet for a new rear end. however some JY's realize their worth and jack the prices up.
I think quadratec sells new harnesses but I think theyre around $500
RikatyJeep is offline
post #3 of 3 Old 08-04-2010, 10:07 AM Thread Starter
bmw328in
It had a small vibration and i just thought it was the universal joint went to change it and the the rear end will turn over a half a turn before the wheels will move
bmw328in is offline
wiring , harness , rear , axle , rebuild kit
how hot is your rearend? slafferty TJ Wrangler Technical Forum 15 03-20-2010 01:06 AM
Rearend Gone Bad Cruzer1966 TJ Wrangler Technical Forum 9 01-19-2007 09:24 PM
rearend help, please TXST8tj TJ Wrangler Technical Forum 2 05-31-2006 02:04 PM
Is my rearend going bad on me? Kraw TJ Wrangler Technical Forum 12 10-31-2005 09:28 PM
ZJ rearend??? crazynut52 YJ Wrangler Technical Forum 1 11-21-2004 07:13 PM
