4.11 or 4.56? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4.11 or 4.56?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE Shipping Sale!FS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 04-21-2015, 06:30 AM   #1
dos0711
4.11 or 4.56?
I'm on the horns of a delima...which ratio? My Wrangler is a 2000 with a non overdrive automatic with lockup converter. Tire size is 32.7 inches in height. I do some beltway driving but mostly inner city with occassional trail riding. I've looked at grimmjeepers gear calculator but my concern is sustained high rpm on the beltway. Does the 4.0 have any issues with sustained 3000-3500 rpm? I've never thought of them as hi revvers...
2000 Wrangler TJ, 4.0 6 cyl, A/T, G2 Dana 44s, ARB Lockers, 4.10 ratio
dos0711 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 06:49 AM   #2
TheBoogieman
Pure Evil Jeep freak!
TheBoogieman's Avatar
Go with 4.56 if you ever plan on moving up to 35s. If not, stick with 4.10. The 4.0 is very happy with higher revs.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 07:29 AM   #3
dos0711
Do you think 4.56 would be too much for 32.7 inch tires? I doubt I'd ever go over 33s.
984
Unread 04-21-2015, 08:17 AM   #4
88hatchy
I'd go with 4.10 gears if you're staying with 33" tires.
1997 TJ - Current project: Simple-ish build
1988 Civic Hatch - Runs 12's, gets 30 mpg
88hatchy is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 08:28 AM   #5
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Based on that stick with 4.10.
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 10:50 AM   #6
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
What speed do you drive on the highway?
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 11:04 AM   #7
Jeepsr4me
I just sold my jeep with auto trans and 32inch tires.. And I had 3.73 gears.. And i had to HOLD the brake pretty hard setting at light due to the jeep wanting to GO.. So I could not imagine 411 gears with the 32s.
Interstate speeds the engine was up there in the RPM range. More so than I liked, but those trips at 70+mph are rare for me in a jeep.
Around town i really liked the gears and could have used 411 just as well.
I had on it a light set up of street tires and light aluminum rims..
I had a set of 35s on heavy steel rims that Were just to large to fit on a stock jeep or I would have tried it.
So if your tires are mud tires or heavy then the 410s will really help
Jeepsr4me is online now   Reply With Quote Quick reply to this message
Unread 04-21-2015, 01:42 PM   #8
dos0711
I run around 65 on the highway...so it sounds like 4.11 gears is the way to go. Thanks all! =-)
152
