4:10, 33's, Dana M35 Rear, Dana 30 Front - JeepForum.com
post #1 of 2 Old 02-10-2004, 02:12 PM Thread Starter
Jeeper-4-Life
I have been reading post after post after post and hearing a lot of different opinions, which is expected. But for clarification, will I be alright to have 4:10's and a trac loc in a stock Dana M35 rear (by the way, what does the M mean???) along with the 4:10's in the stock Dana 30 Front? I will be running 33's and do not plan to go bigger, I also do a lot of street/highway driving and offroad when I can, mainly dunes and trails...limited amount of rocks and very little mud.
2001 TJ
BDS 2" BB
32" MT/R's
Jeeper-4-Life is offline
post #2 of 2 Old 02-10-2004, 03:48 PM
KaiserJeep
You can get away with more tire and higher gearing on the road than offroad. But what's a Jeep for?
You can get away with more tire and higher gearing if you drive around like an old man all the time. But what's a Jeep for?
You can get away with more tire and higher gearing with a 2.5L - but you have the 4.0L I see.
You can get away with more tire if you re-gear to restore the stock RPMs, but you are not doing that - the natural tendancy is to use more throttle to restore acceleration - bad idea, but you can't help it.
You already knew all this, based on the way you asked the question. I'm not gonna encourage you, because I think you have already made up your mind to go ahead. I would encourage you to have a good backup plan - like hiking shoes, a canteen, and a couple of days of food. For when the axle breaks.
Even if you had the money and the desire to upgrade all the weak pieces, you might still break something and be stranded miles from the road - it's just less likely. Be prepared.
Edit: M35 is Dana Model 35 differential. The actual Jeep model axle is a Dana 194RBI, where R = Rear Axle, B = Beam Axle Design, I = Iron differential construction, and 194 is the diameter of the ring gear in millimeters.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
Dana 44 front Dana 35c rear? yghong2204 TJ Wrangler Technical Forum 23 12-30-2009 02:04 PM
Dana 30 Front, Dana 60 Rear???? MMerrick YJ Wrangler Technical Forum 7 01-07-2008 12:51 PM
Dana 30 front and Dana 44 rear robisha2 TJ Wrangler Technical Forum 18 07-31-2007 10:49 AM
(2) Dana 44s or Dana 44 in rear and 35 front Ethan03 TJ Wrangler Technical Forum 27 06-14-2006 12:04 AM
Can REAR Dana 35 4.11 work with FRONT Dana 30 4.10 4.2-blackone YJ Wrangler Technical Forum 11 04-03-2006 11:22 PM
