4:1 low transfer case, why do I want one? - JeepForum.com
post #1 of 18 Old 07-16-2010, 07:37 AM Thread Starter
viperbluelx
I know the Rubicons come this way from the factory so obviously it's gotta be an upgrade over the factory TJ transfer case. I have 4.10 gears and 33's with a 32RH and in 4LO mine seems geared very low and it crawls in 1st gear. When we go offroad it's usually tight trails, hill climbs, rocks, and a few small mud holes when they are unavoidable. How would I benefit from a 4:1 low?
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #2 of 18 Old 07-16-2010, 07:42 AM
crusher242
4:1 would put you into even more of a "crawl gear". Combined with an auto tranny, you'll have a dirt cheap and fair reliable crawler. You'll just break everything else. I'm a mud guy. I like my 2.72 gearing for mud so I can spin my tires with ease in a sticky situation. A 4:1 would be way to low for someone like myself.
Hold onto something... Quick!!!
crusher242 is offline
post #3 of 18 Old 07-16-2010, 08:21 AM
-dirt-
I really enjoy the compression braking when going down steep hills (I have a manual). Both ascents and descents are very controllable.
-dirt- is offline
post #4 of 18 Old 07-16-2010, 08:48 AM
Zen
If you don't do a lot of technical rock crawling, I wouldn't do the swap.
On flat ground in 4L with the auto in 1st gear I can hop out of the Jeep and walk along with her. I have to use two feet on the brake pedal while doing technical crawling or she won't stop right away. Going down a steep grade it's absolutlety amazing how slow the Rubicon goes when engine braking.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #5 of 18 Old 07-16-2010, 08:58 AM
jeep rio
as stated 4.1 is nice on rocks and in very steep terrain however for what you've stated that your doing its not really necessary.
1997 XJ Sport 2 Door- High country suspension and skid plate package.
2006 TJ- Custom lift 4in Full traction springs, OME shocks, Kilby skid plates and bumper, Full traction 3 link in rear, JKS control arms upper lower, Banks exhaust, Edge trail jammer, 4.56's and true trac front, Eaton elocker rear. D30, D44
1995 YJ Rio Grande- 4.0l Swap 3.5 in 4wd hardware lift, Ford 8.8 Rear 4.10 gears.
jeep rio is offline
post #6 of 18 Old 07-16-2010, 09:14 AM
Apex
Recon death squad
Apex's Avatar
I had 33s, 4.10s and the 32rh...I would do almost 5mph downhill if I let off the brakes. That is what made me desire 4:1.
Apex is offline
post #7 of 18 Old 07-16-2010, 10:01 AM
Zen
Your avatar is the right environment for 4:1 .
If you read his post and thought "5MPH doesn't seem fast." You don't need a 4:1 transfer case.
-Stick, splash one!
Zen is offline
post #8 of 18 Old 07-16-2010, 10:18 AM
bandit455
4:1 becomes even more prevalant with a stick, when your geared real low you no longer have to do a ton of clutch work on the rocks. you can just idle over so much more. Going from 3.07's to 4.56's I am in love with the new crawl ratio I have, but in the grand scheme of things its still not that low, and in the real technical stuff that lower ratio would be great.
look at the yota guys, many run two range boxes with one or both having 4.7:1 gears. when it comes to rock, crawl speed is king.
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #9 of 18 Old 07-16-2010, 10:39 AM
Recoil
Recoil's Avatar
1988 MJ Comanche
Yeah with 4:1 it's fun to stick your feet outta the jeep on a gnarly rock garden and see peoples eyes widen. That's with the 6 speed.
Recoil is offline
post #10 of 18 Old 07-16-2010, 06:10 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
If you do get the 4:1 low range, get the 2Low to go with it...
Knuckelhead is offline
post #11 of 18 Old 07-16-2010, 06:13 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I haven't even wheeled with my 4:1 yet in the new Rubicon but together with its automatic and 4.88 gearing, I can't wait to get it onto the rocks. Hopefully it'll be ready for a Big Bear group run scheduled for the end of this month but it's gonna be tight.
Jerry Bransford is online now
post #12 of 18 Old 07-16-2010, 06:17 PM
danielbuck
1946 CJ2
yea, it's amazingly slow with 4:1 in 1st 4lo with 4.10 gears, going down steep hills I often never even have to hit the brakes, haha! And up hills too, nice and slow. I originally thought I'd never need 4lo very often, but I find that I like it alot! I don't do mud or water though.
And first gear on mine seems to be real slow even in 2 wheel drive with 32" tires and 4.10 gears. I hardly ever use first gear on the street, I pretty much always start out in 2nd. Maybe the 6 speed has a lower 1st gear than the other transmissions?
danielbuck is offline
post #13 of 18 Old 07-16-2010, 06:18 PM
never monday
Beasley Knob doesn't need 4:1
never monday is offline
post #14 of 18 Old 07-16-2010, 06:24 PM
freeskier93
4:1 is great for automatics that do rock crawling because it allows them to move slower at idle. With a manual it would make it 1000 times easier to do anything because you don't have to use the clutch as much, if at all.
Will also make going downhill easier.
freeskier93 is offline
post #15 of 18 Old 07-16-2010, 06:35 PM
breckboarder55
If you have to ask you probably don't need one (yet anyways).
Put your money towards something you want/need until you reach that point. Don't buy it because its the thing to do.
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
4:1 , low , ratio , rubicon , transfer case
LOUD violent POP from transfer case on occasion from my lifted Rubicon transfer case anymanusa TJ Wrangler Technical Forum 14 07-23-2010 04:54 PM
Transfer case boot for 231c transfer case in jeep wrangler kniteman YJ Wrangler Technical Forum 2 03-16-2009 01:28 PM
Bent rear diff and cracked transfer case, what diffs and case will bolt into my 87 YJ hillside250 YJ Wrangler Technical Forum 9 01-08-2009 12:45 AM
transfer case issues 91 auto to 88 standard case... input shaft?? dream911tommy YJ Wrangler Technical Forum 1 12-22-2008 11:23 AM
Diff and transfer case fluid transfer hint BillArf TJ Wrangler Technical Forum 11 06-26-2005 07:42 AM
