4.0L Engine Swap Questions - JeepForum.com
post #1 of 3 Old 07-23-2010, 01:06 PM Thread Starter
Black Hills TJ
Black Hills TJ's Avatar
Hey Guys,
I found a 4.0 out of a 95 XJ with an automatic transmission that I am considering picking up for a little engine swap. How much work would this be, if its even possible without busting your *** to make it work?
I also found a 4.0 out of a 2004 Grand Cherokee with the transmission and transfer case. The prices are right, but how much of a process would it be to make this work?
Thanks,
Mike
Originally Posted by Allenwr
My mouth still has funky taste in it, so I am doin alright.
Originally Posted by ImSuck
damnit i wish i could get bigger quicker
Check out
Black Hills TJ is offline
post #2 of 3 Old 07-24-2010, 08:06 AM Thread Starter
Black Hills TJ
back to page 1
Check out
post #3 of 3 Old 07-24-2010, 08:15 AM
bairy
Do a search on swaps. It is a lot of work. Complete wiring swap and even grinding off old frame motor mounts and welding new ones on. there are some long lists people have written up what needs to be done from a TJ2.5 to a 4.0. I am sure there are lots more issues when coming from cherokees.
Might as well drop a v8 dodge in there.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
4.0 , engine swap , xj , wj , cherokee , grand cherokee , tj , wrangler , swap
Engine Swap questions??? Dually TJ Wrangler Technical Forum 5 12-20-2009 07:23 PM
2.4 to 4.0 Engine swap questions BWFBezerk TJ Wrangler Technical Forum 5 04-05-2009 10:04 AM
Engine Swap Questions KevinR TJ Wrangler Technical Forum 5 02-28-2009 06:55 PM
Engine swap questions P8ntblr160 TJ Wrangler Technical Forum 4 08-06-2007 04:01 PM
