4.0 Starts for 3 seconds then stalls. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4.0 Starts for 3 seconds then stalls.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 09-21-2009, 03:49 AM   #1
darkhollow2738
My 04 Rubicon is acting like a chump this morning and stalls after 3 seconds. I thought I heard a little plunger noise coming from the rear over the last few weeks. I'm thinking it's the fuwl pump. Any suggestions?
darkhollow2738 is offline   Reply With Quote
Unread 09-21-2009, 05:11 AM   #2
1CleanTJ
fuel pump wouldnt make a sound like that, a plunger noise in the rear on your year wrangler would probably be part of the emissions system. As for the starting issue, does it stay running if you give it some gas while starting it ?
1CleanTJ is offline   Reply With Quote
Unread 09-21-2009, 05:24 AM   #3
darkhollow2738
No; you can rev it up but it will die after 3 seconds.
Unread 09-21-2009, 06:09 AM   #4
blinx
MAP Sensor will cause that behaviour as well. I would check for vacuum leaks and/or make sure the sensor isn't bad. I only had 1 go bad on all my jeeps over the years - but it was the same as what you are experiencing. It was a pain to track down but its easy to test (need a hand vacuum pump and a VOM):
How to Troubleshoot a MAP Sensor | eHow.com
blinx is offline   Reply With Quote
Unread 09-21-2009, 06:22 AM   #5
Scotch740
Why would a jeep be able to run if the vacuum line came of the manifold then? The MAP sensor would be showing 0in-Hg so wouldn't that mess with it, more so than just throwing a code? Or is there some over ride on the system.
For a quick temp fix could you just unplug the vacuum line from the manifold? Or possibly just unplug the MAP sensor? Or is a 0 voltage output likely the culprit of this?
Scotch740 is offline   Reply With Quote
Unread 09-21-2009, 07:01 AM   #6
mdm
Farm Wheeler
...stalls after 3 seconds...
Does it have the Sentry security system?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote
Unread 09-21-2009, 08:01 AM   #7
blinx
Because if the MAP sensor loses vacuum or is otherwise faulty - one of the things it will do is starve the vehicle of fuel. Guess you don't know what a MAP sensor does so here is a link:
MAP sensor - Wikipedia, the free encyclopedia
Unread 09-21-2009, 08:11 AM   #8
Scotch740
I was asking why will my jeep will continue to run even though my vacuum line is off my manifold, thus the MAP has no vacuum.
Or maybe I am mistaking on the vacuum line that goes to the MAP sensor. Is that the same line that controls the air flow vents selector?
This one?
Unread 09-21-2009, 08:51 AM   #9
darkhollow
Yes it does have the sentry alarm?
Yes it does have the sentry security.
darkhollow is offline   Reply With Quote
Unread 09-21-2009, 09:30 AM   #10
mdm
Farm Wheeler
With this system, if you attempt to start the engine with a key that is not a chipped key or one that is not programmed into the Sentry system, the engine will start and die after a few seconds. There are some Sentry system faults that will do the same thing even with a properly programmed key.
Unread 09-21-2009, 12:38 PM   #11
darkhollow2738
The problem was that I had used a spare key that I had made for the first time. It wouldn't start without a chrysler key.
Unread 09-21-2009, 12:44 PM   #12
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
X2, your symptom is exactly what a bad Sentry key or bad Sentry key system would cause.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 09-21-2009, 03:14 PM   #13
dhk
This is why I didn't get the Sentry Key system on my TJ.
dhk is offline   Reply With Quote
Unread 09-21-2009, 03:25 PM   #14
mdm
Farm Wheeler
Why? The Sentry system is pretty good. It does exactly what it is designed to do. All you have to do is follow the instructions.
