4.0 stalls occansionally when RPMs drop quickly - JeepForum.com
post #1 of 5 Old 10-09-2008, 01:31 PM Thread Starter
Chad184
I have a 98 Sahara Edition and it tends to stall when the RPM's are above 2,000 and I lift my foot of the pedal. I'm a new Jeep owner, have had it off road every weekend since I bought it - so much fun, but am worried I might have an idler problem, or in need of a cat replacement.
Chad184 is offline
post #2 of 5 Old 10-09-2008, 04:01 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That problem is generally/usually caused by a dirty IAC (idle air controller). The IAC is mounted to the passenger side of the throttle body and is responsible for providing all of the engine's air when at idle and the butterfly valve is closed (when your foot is not on the accelerator pedal).
The IAC gets dirty over time and when it does, it can't open smoothly enough so it won't provide engine air well enough for a smooth idle.
Held on by two small torx-head bolts, the IAC is easily removed and cleaned... there is usually no need to replace it. Buy an aerosol can of throttle body cleaner and with a rag and/or toothbrush, gently clean the IAC's solenoid actuated plunger which is what fits into the throttle body to control the amount of air that gets into the throttle body. Don't push/pull/twist/turn that plunger. Clean the oriface the plunger fits into too. Once the IAC is clean and reinstalled, use the rest of the throttle body cleaner to clean the inside of the throttle body per the instructions on the can.
Here's a diagram showing where it is. Notice that slot labled "Idle Air Control Passage Inlet"? That's where the TB gets its air through at idle as controlled by the IAC. Good luck and a big welcome to JF.
Getting
Jerry Bransford is offline
post #3 of 5 Old 10-09-2008, 04:04 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
That covered it and welcome.
TheBoogieman is offline
post #4 of 5 Old 10-09-2008, 11:16 PM Thread Starter
Chad184
WOW! Thanks for the quick reply. I looked at it tonight and will be able to clean it this weekend (not a daily driver) as long as the snow melts a bit.
Chad184 is offline
post #5 of 5 Old 10-10-2008, 01:54 AM
97casteeltj
97casteeltj's Avatar
its 70*+ here!!! i wonder when it will cool off!!
-John
needing a new rig....
97casteeltj is offline
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 10:22 PM
4cylinder Hard to Start / Stalls / only runs smooth in mid RPMs carcollector TJ Wrangler Technical Forum 0 01-05-2010 11:35 PM
stalls in 3rd gear at 2400 rpms dillon5458 YJ Wrangler Technical Forum 0 08-16-2009 02:53 PM
RPMs drop after reserve plyguitar45 YJ Wrangler Technical Forum 1 02-19-2009 11:14 PM
RPM's drop quickly between shifts? boomhower YJ Wrangler Technical Forum 5 02-27-2005 11:15 PM
