4.0 Spark plugs - JeepForum.com
post #1 of 7 Old 02-14-2009, 12:29 PM Thread Starter
onlyn8v
4.0 Spark plugs
Im going to change my plugs for the first time (25k miles) and I remember there was a post that said do not use ____ plugs in the 03-06 engines. Can you guys give me some more info and recommend the brands you guys use?
I searched- but my search is somewhat limited
Dave
1990 VW Corrado Turbo
1998 VW Jetta TDI
1999 VW Jetta TDI 4 SALE!!
onlyn8v is offline
post #2 of 7 Old 02-14-2009, 01:22 PM
inutero1212
i have used the E3's my dad got me for x-mas and no issues thus far. Sock ole brand worked okay as well other than having to regap every single one of them.
inutero1212 is offline
post #3 of 7 Old 02-14-2009, 01:55 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You want to avoid any single-tipped platinum plugs on newer engines that don't have a distributor which is the kind of engine you have. A very good choice for newer 4.0L distributorless engines like yours is the double-tipped Autolite APP985 which will last 90-100K miles. Make sure to avoid the AP985 which is only suitable for older 4.0L engines that have a distributor.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #4 of 7 Old 02-14-2009, 01:58 PM
Pillswoj
Do not use single platinum plugs, it will cause misfires on the coil pack equipped TJ's. I would suggest the Autolite APP985 plugs which are double platinum, they will last forever. Otherwise just go conventional copper and replace every 30000.
Friends don't let Friends run Bosch
Pillswoj is offline
post #5 of 7 Old 02-15-2009, 06:05 AM Thread Starter
onlyn8v
Im going to grab the APP985's thanks!
Dave
1998 VW Jetta TDI
onlyn8v is offline
post #6 of 7 Old 02-15-2009, 01:30 PM
silvanus
I have them in my L J,and the ol' 4.0 is running tight. Go for it!
silvanus is offline
post #7 of 7 Old 02-15-2009, 01:34 PM
M2LJ
Go to Amazon.com for them, I got a great deal from them on the Autolite APP985 plugs!
Cheers! M2
M2LJ is offline
Need Spark Plugs - Can't find the Champion Truck Plugs #4412 2004JeepTJ TJ Wrangler Technical Forum 29 09-17-2011 08:37 PM
Spark plugs twarden TJ Wrangler Technical Forum 7 03-28-2008 02:59 PM
E3 Spark Plugs cheesycook TJ Wrangler Technical Forum 3 08-24-2006 07:12 AM
Spark Plugs JeeperAbe TJ Wrangler Technical Forum 4 03-15-2006 04:49 PM
Spark Plugs cwbyup TJ Wrangler Technical Forum 2 02-19-2004 08:47 PM
