4.0 seeping oil on passenger side head gasket - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 4.0 seeping oil on passenger side head gasket
USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Eliminate Hood Flutter!!!Offset Tie Rod Kit From RuffStuff!
Unread 09-29-2013, 06:20 PM   #1
bkohler2005
Do these 4.0 just plain and simply leak? This is a reman engine with 12k on it. I have very small amount of oil seeping from the passenger side of the head gasket where it meets the block. Its not much but is blown/ runs back and down the back side of the block and creats a drip on the bottom of the flywheel cover. It does not drip unless it sits for a week or so and then its a single drop. Is anyone else having this issue, is it normal.... because its driving me nuts.
bkohler2005 is offline   Reply With Quote
Unread 09-29-2013, 06:41 PM   #2
2003RubiBlue
Are you sure its not the valve cover. The head gasket should not leak at all.
Quote MrBlaine:
"That's awesome advice. Anytime I have a difficult repair, I fix something else that's much easier to get to. This one time, there was a hole in the oil pan so I replaced the side mirror on the driver's door."
Wanted: Tuffy rear underseat drawer. PM me if you have one.
2003RubiBlue is offline   Reply With Quote
Unread 09-29-2013, 07:06 PM   #3
bkohler2005
yes, its not the valve cover. Dry as a bone all the way around.
Unread 09-29-2013, 07:44 PM   #4
2003RubiBlue
I've never run into one that was leaking oil externally on the head gasket. No oil in the coolant, coolant in the oil I would run it until it gets worse, but that is not normal. Any warranty on the reman.
Quote MrBlaine:
Unread 09-29-2013, 08:37 PM   #5
bkohler2005
yea, no mixing of fluids. Its a Napa auto parts reman engine. I think they will warranty the gasket but the labor? I would just do the job myself, but just one more thing to have to find time for. Was not impressed with the shop that put the engine in. I hate oil leaks!
Unread 09-30-2013, 03:20 AM   #6
Necko2529
Surfing JF Since '04
Necko2529's Avatar
What would make a 4.0 just plain leak? Im pretty sure DC hasn't engineered leaks of any kind in the 4.0 from the factory so i would say no, the leak is not something that's normal.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline   Reply With Quote
Unread 09-30-2013, 05:24 AM   #7
bobjp
It's not normal, and I would be worried about it. If it can leak there, then it can eventually start leaking into the coolant the the cylinders. I wonder if there's a flatness issue with the head or block?
97 TJ sport.
bobjp is online now   Reply With Quote
Unread 09-30-2013, 03:19 PM   #8
TravisHeim
I don't really see how it could be leaking oil in that location and not have some serious combustion/cooling issues. Not much going on in that part of the block, its just a passageway for the push rods and oil to return from the head. Have you considered having a dye test done?
TravisHeim is offline   Reply With Quote
Unread 10-01-2013, 08:04 AM   #9
bkohler2005
I am taking it to the shop that put the engine in it this saturday. We will see what they say. Kinda between a rock and a hard place, the engine is still under warranty but I was not too impressed with the work the shop did putting in the engine. If I do the work myself, I void the warranty....
Unread 10-01-2013, 08:19 AM   #10
Necko2529
Necko2529's Avatar
In this case, keep taking it back until they work all the bugs out...
Unread 01-02-2014, 09:21 PM   #11
bkohler2005
Figured it out, after pulling the head myself. I found that when the block was machined for remanufacturing the engine, they left some grooves in the top of the block on the right side. The oil has been seeping thru, running back and down the rear of the engine. I buffed them smooth and had the head flattened by a machine shop. Then went back together with it. That was 500 miles ago. No more oil leaks.
Unread 01-03-2014, 08:34 AM   #12
Vinman
Why did you feel the need to have the head machined when the grooves were in the block?
Vinman is offline   Reply With Quote
Unread 01-04-2014, 11:04 AM   #13
bkohler2005
To make sure it was a flat surface to reseal. Which it was not. Each end was higher than the center. I even untightened it in the correct sequence. The inline six cylinder engines head is longer and easier to warp when removing, I didn't want any excuse for it to leak later and say well I should have done...... Fix it right the first time and there won't be a second time.
