4.0 Oil Pan Removal - JeepForum.com
post #1 of 17 Old 10-05-2009, 01:31 PM Thread Starter
MikeRi24
4.0 Oil Pan Removal
I need to replace my oil pan on my '03. A friend of mine who is a mechanic said after looking it up in a chilton's manual, the motor mounts need to be disconnected and the motor lifted up a few inches to allow for the right clearance. I looked under the thing, and I really don't see how theres not enough room if you take the exhaust off. If need be, could I drop the front axle a little bit to make room? that would be a LOT easier for me to do than jack the whole motor up.
Mike
2003 Jeep Wrangler X
My Build Thread:
"My Jeep helped win a war....You're Honda just mowed my lawn"
MikeRi24 is offline
post #2 of 17 Old 10-05-2009, 01:44 PM
mdm
Farm Wheeler
The FSM says to lift the engine. All you are doing is getting enough clearance to be able to remove the pan. You could do it by lifting the engine or dropping the axle.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 17 Old 10-05-2009, 02:35 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
It is easier to just undo the four exhaust bolt from the mainifold and then you can get to all of the bolts. Remember to keep the bolts in the proper sequence as there are a few different type.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #4 of 17 Old 10-05-2009, 02:35 PM Thread Starter
MikeRi24
Yeah, I put my budget boost in and I have the feeling by disconnecting the sway bar and the shocks, I could drop the axle down at least a few inches to get to it. I was planning on disconnecting the exhaust at the downpipe and then sawzall-ing it off somewhere near the transmission skidplate and then just welding it back together after so its totally out of the way.
Mike
My Build Thread:
MikeRi24 is offline
post #5 of 17 Old 10-05-2009, 02:39 PM
RYANSTULC
No need to loosen motor mounts, or remove the axle.
As stated above, simply remove the exhaust @ the bottom of the collector, and remove the pan.
It's usually a two-person job two slightly pry back the exhaust while the other person carefully
drops the pan.
Super simple. I've done it a number of times on my '98
And definitely keep track of which bolts go where. There's a number of smaller bolts, and (4) slightly bigger ones. Some of the smaller bolts have a longer shaft that is used to connect the transmission cooler lines.
Once you see it, it'll make sense.
RYANSTULC is offline
post #6 of 17 Old 10-05-2009, 03:00 PM
Srgslaughterav
Srgslaughterav's Avatar
Just a tip. You may allready do this. For those of you that don't... I get a peice of cardbord. Mark front on one side. As you take a bolt out punch it through the cardboard in its corisponding location to the oil pan. I found that if I get side tracked during the project or have to let it sit overnight. I have a hard time remembering where the bolts go. So this way I don't have to try to remember. Just a little tip to help out.
4" short arm lift, Anti rock sway bars front and rear. hard rock Front and rear bumbers, Warn 9.5ti winch,Undercover fab engine and tc skid,genright extreme gas tank, AtoZ Fabrication rocker guards, metal cloak fenders all around,JKS bar pin elminators, Viair Extreme Duty OBA system, Cobra CB, 37'' iroks on trailready beadlocks , NP231 Novak shifter tera low 4:1 with 2 low kit and SYE , CV ds, rockjock 3 front and rear dana60's with front and rear ARB with 4:88's.PSC hydro assist
Srgslaughterav is offline
post #7 of 17 Old 10-05-2009, 03:04 PM
Mttrek360
Thats what I do
Pics or it didn't happen.
Mttrek360 is offline
post #8 of 17 Old 10-05-2009, 04:09 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Drop the downpipe, 4 bolts at collectors by manifold and 3 before cat.Take note of the orientation of the oil pan bolts.Easy job for 1 man.
GOLENJEEPTJ is offline
post #9 of 17 Old 10-05-2009, 11:35 PM
RYANSTULC
This can be a challenge is you have a RELA kit.
I've only been able to remove the exhaust from the collector, and that's it.
Little bit of strong-arm'n the exhaust and the pan will pop out.
post #10 of 17 Old 10-06-2009, 07:24 AM
F9K9
Originally Posted by provelogear View Post
.........Remember to keep the bolts in the proper sequence as there are a few different type.
+1 and a PITA!
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #11 of 17 Old 10-26-2009, 12:52 PM
jpconard
To re-visit this question. I hit mine on a rock this weekend near the drain bolt, creased the metal near drain bolt and twisted it some. Not real deep dent, but something I want to replace in near future.
For a stock vehicle, removing the exhaust and possibly jacking up body (but leaving motor mounts alone), should give enough clearance between pan and front axle, correct?
What else needs to be removed back by the bell housing (manual transmission)?
I plan on replacing pan and getting the terraflex HD skid (similar to the Nth degree) - mounts to bell housing and up front to sides of motor.
jpconard is offline
post #12 of 17 Old 10-26-2009, 12:56 PM
GOLENJEEPTJ
I do have a LA and it's not a challenge?Just drop the down pipe and get it out of the way?
post #13 of 17 Old 10-26-2009, 06:21 PM
bosoxfan455
i had the same thing happen, i put my jackstands next to the lca mount on the frame and took the front wheels off. the axle was at full droop and i just unbolted the exhaust at the collector. although on mine i had to disconnect the bracket on the transfer case to move the exhaust enough.
i went with the aev/nth skid and no complaints except the hardware wasnt included with my initial purchase from quadratec. a quick phone call to qtec's customer service and a hardware kit was on its way
one final bit of advice is maybe plan on doing a oil pump too, the pickup may have bent but you wont really know til you get in there
bosoxfan455 is offline
post #14 of 17 Old 10-26-2009, 06:52 PM
marylandjeeper
when i did mine i put jackstands on the frame and let the axle droop all the way down, unbolted the downpipe from the manifold and got the old pan off. it took a good bit of pulling on the exhaust to get it out, and it came out just barely. i couldn't see how i would get the new one in place without messing up the gasket and rtv. i ended up cutting the exhaust right by the t/c skid and the new one went on much easier without the downpipe in the way. my oil pump was fine, and i did a new rear main seal while i was in there, not because it was leaking but because i was going through all the trouble of replacing the pan anyways. i also got a pan from napa and was disappointed by the quality, and a mopar pan was only $40 more and was much nicer.
Everything we sell is US Chinese made! I'm Chinese so it is Made in the USA by a China Man! HAHAHAHAH!
Originally Posted by IKate
It's not "made BY chinese" that's the issue, it's "Made in China" that's the problem - now you behave yourself.
marylandjeeper is offline
post #15 of 17 Old 10-27-2009, 09:09 PM
TJRUSSELL
i thought you were selling it mike?
TJRUSSELL is offline
A/C Removalů AR-Guy YJ Wrangler Technical Forum 11 11-03-2010 08:55 AM
Air Dam Removal liquidean JK Wrangler Technical Forum 8 09-11-2009 04:12 PM
Oil Pan Removal Help TjBryce TJ Wrangler Technical Forum 3 09-06-2009 05:21 PM
CPS removal seattlejeepster YJ Wrangler Technical Forum 0 03-01-2008 06:04 PM
HT Removal Sidewalkman YJ Wrangler Technical Forum 4 07-12-2003 08:14 PM
